Moving to the Farm
   / Moving to the Farm #531
Happy New Year.
I finally got a tree that had fallen over my path pulled up to where I could work on it. The boys helped me process some more wood too.
More Wood Anyone | homesteaddad
   / Moving to the Farm #536
Looks good. You said in your write up that you wanted it in three studs but a hook was in the way. Can you get some long screws to match the hooks? If so just replace the short ones with longer ones.
Great idea. I may see if I can find some. I am sure it is more than adequate the way it is now, but I try to overbuild whenever possible. Thanks for the tip.
   / Moving to the Farm #539
I had a thought about the quail water. Would a coffee cup heater under their water dish make it too hot? {Maybe put it on a timer?} I see them at thrift shops all the time for a buck. Also when I was in the Navy we used the heating elements from coffee pots to make water heaters. Those can also be found cheap in thrift stores.
Larro
I made a water heater using a lamp kit. I took a cookie tin, drilled a hole in the side and am using a 100 watt light bulb to keep the tin warm and thus the water warm. Working so far.
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
Magnum 125 Generator (A53421)
Magnum 125...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A55218)
2017 Yale GLC050VX...
