Moving to the Farm
   / Moving to the Farm #531
Happy New Year.
I finally got a tree that had fallen over my path pulled up to where I could work on it. The boys helped me process some more wood too.
More Wood Anyone | homesteaddad
   / Moving to the Farm #536
Looks good. You said in your write up that you wanted it in three studs but a hook was in the way. Can you get some long screws to match the hooks? If so just replace the short ones with longer ones.
Great idea. I may see if I can find some. I am sure it is more than adequate the way it is now, but I try to overbuild whenever possible. Thanks for the tip.
   / Moving to the Farm #539
I had a thought about the quail water. Would a coffee cup heater under their water dish make it too hot? {Maybe put it on a timer?} I see them at thrift shops all the time for a buck. Also when I was in the Navy we used the heating elements from coffee pots to make water heaters. Those can also be found cheap in thrift stores.
Larro
I made a water heater using a lamp kit. I took a cookie tin, drilled a hole in the side and am using a 100 watt light bulb to keep the tin warm and thus the water warm. Working so far.
2023 Country Clipper Boulevard 54in Zero Turn Mower (A52377)
2023 Country...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
1979 Chevrolet Step Van (A52377)
1979 Chevrolet...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2014 Jeep Patriot (A53424)
2014 Jeep Patriot...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
