Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #671
The cross beam may not be necessary, but I'd prop a pole under the middle of the high beam against a monster heavy snow. Is that maybe a 18-20' span? Long way for any sawn beam.
Nice shed though. Good to be able to work in some weather, and keep it off the saw.
Jim
   / Tractors and wood! Show your pics #672
Jim
That crossbeam isn't doing much at all. I see a turnbuckle or something that looks like it is screwed or bolted in to help counter potential load but it sure doesn't look like a well engineered design. I suspect if the cantilever beam gets much load due to deflection of the front roof beam, the lag screws will pull out. Anyways, sorry but I can't help but to look at structural details like that.
   / Tractors and wood! Show your pics #673
I noticed that extension off the back and wondered why it was there. Great idea, not sure it could be made to work, but interesting.
He didn't, there's no hinging and all the bracing is fixed.
Then it must be there to hold that top link from his tractor in place.
   / Tractors and wood! Show your pics #674
   / Tractors and wood! Show your pics #676
20140413_175303.jpg Had to split it down the middle
   / Tractors and wood! Show your pics #677
   / Tractors and wood! Show your pics #678
My splitter built in 2009 IMG_0997.jpg This is with the 30 " cylinder. I have since then cut it down to a 24" cylinder. I stand upright all the time. No bending over if I can help it. Auto cycle valve. I have also made a 4 way wedge for it.
   / Tractors and wood! Show your pics #680
I will need to look into that HD filter. Thanks for the info
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
Toro Zero Turn (A50324)
Toro Zero Turn...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
