How much does a Kubota mx 5200 weigh?
   / How much does a Kubota mx 5200 weigh? #1
namesray
nc PA.
kubota rtv900: kubota mx5200
I am narrowing down decision on rather to upgrade to a larger tractor. I am looking for the total weight of a kubota mx 5200 with fel and loaded r4 tires. The pamphlet says weight is 3716 lbs, but that is just the tractor. I dont think that even includes loaded tires. I am guessing 3700 for the tractor, 1100 for the fel, and 600 for loaded tires for a total weight of 5400 lbs. Am I even close. I would like to know, so I can figure out if I can haul it. Thanks in advance.
   / How much does a Kubota mx 5200 weigh? #2
My 5100 setup the same, I've estimated the loader about 1500 and I think tires filled are 1000 total.
What trailer and truck are you trying to use?
   / How much does a Kubota mx 5200 weigh? #3
Yep, I think you are underestimating the loader.
Call the dealer. The weight of the loader is listed in the loader manual. My much smaller loader is ~900. But those weights are WITHOUT the bucket. My little 5' bucket is ~260. So my total loader weighs 1160. I wouldnt be surprised if you are 1500+.
You can look up a fill chart online for the tires. Alot depends on what it is filled with.
I have a 1992 1 ton chevy dump. Trailer would be "down to earth" 20FT long, rated for 10k. Dealer says load tires with antifreeze.??. So 3716+1500+1000=6216lbs. Guessing trailer to weigh around 2500lbs. Going to be close to maxing out truck tow rating after add implement I am guessing.
   / How much does a Kubota mx 5200 weigh? #5
I think you are underestimating the whole thing - namesray. My Kubota is listed at 4785 lbs. However, after I added all the extras - loader w/bucket @ 2010lbs, rim guard in rear tire @ 1476lbs & ROBB @ 710lbs it was 8980lbs for an estimated total. I then drove in town and put it on the grain scales and (without me) it said 9338lbs.
I checked and the listed weight for the tractor DOES NOT include any fluids. I calculated that all the fluids will weight right at 360lbs for my tractor.
The estimated weight plus the fluid weight brings it right up to what the grain scales showed.
   / How much does a Kubota mx 5200 weigh? #6
Truck more than enough. I pull with a 3/4ton. Trailer is questionable. I use a 14k 22' trailer with a hauling capacity of 10k.
The dealership is delivering tractor, fel, bushhog, box blade on this trailer if I buy it. It is one of those package deals. The trailer does seem to be a weak link in these package deals. But this "down to earth" trailer seem to look good. Hard to tell/buy with out seeing. Down to earth trailers, is headquarters in georgia.
Truck would seem to be more then enough, as I have already towed 6500lbs with it no problem what so ever, and a contractor I know hauld a mx5100 fel and back hoe with his 3/4 ton dodge ram and he goes all over places.
   / How much does a Kubota mx 5200 weigh? #9
My manual states the FEL weighs:
Loader 1,300
Bucket 397 lbs (HD round back)
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
2007 Ingersoll Rand P185 Air Compressor (A50860)
2007 Ingersoll...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
