How much does a Kubota mx 5200 weigh?
   / How much does a Kubota mx 5200 weigh? #1
namesray
nc PA.
kubota rtv900: kubota mx5200
I am narrowing down decision on rather to upgrade to a larger tractor. I am looking for the total weight of a kubota mx 5200 with fel and loaded r4 tires. The pamphlet says weight is 3716 lbs, but that is just the tractor. I dont think that even includes loaded tires. I am guessing 3700 for the tractor, 1100 for the fel, and 600 for loaded tires for a total weight of 5400 lbs. Am I even close. I would like to know, so I can figure out if I can haul it. Thanks in advance.
   / How much does a Kubota mx 5200 weigh? #2
My 5100 setup the same, I've estimated the loader about 1500 and I think tires filled are 1000 total.
What trailer and truck are you trying to use?
   / How much does a Kubota mx 5200 weigh? #3
Yep, I think you are underestimating the loader.
Call the dealer. The weight of the loader is listed in the loader manual. My much smaller loader is ~900. But those weights are WITHOUT the bucket. My little 5' bucket is ~260. So my total loader weighs 1160. I wouldnt be surprised if you are 1500+.
You can look up a fill chart online for the tires. Alot depends on what it is filled with.
I have a 1992 1 ton chevy dump. Trailer would be "down to earth" 20FT long, rated for 10k. Dealer says load tires with antifreeze.??. So 3716+1500+1000=6216lbs. Guessing trailer to weigh around 2500lbs. Going to be close to maxing out truck tow rating after add implement I am guessing.
   / How much does a Kubota mx 5200 weigh? #5
I think you are underestimating the whole thing - namesray. My Kubota is listed at 4785 lbs. However, after I added all the extras - loader w/bucket @ 2010lbs, rim guard in rear tire @ 1476lbs & ROBB @ 710lbs it was 8980lbs for an estimated total. I then drove in town and put it on the grain scales and (without me) it said 9338lbs.
I checked and the listed weight for the tractor DOES NOT include any fluids. I calculated that all the fluids will weight right at 360lbs for my tractor.
The estimated weight plus the fluid weight brings it right up to what the grain scales showed.
   / How much does a Kubota mx 5200 weigh? #6
Truck more than enough. I pull with a 3/4ton. Trailer is questionable. I use a 14k 22' trailer with a hauling capacity of 10k.
The dealership is delivering tractor, fel, bushhog, box blade on this trailer if I buy it. It is one of those package deals. The trailer does seem to be a weak link in these package deals. But this "down to earth" trailer seem to look good. Hard to tell/buy with out seeing. Down to earth trailers, is headquarters in georgia.
Truck would seem to be more then enough, as I have already towed 6500lbs with it no problem what so ever, and a contractor I know hauld a mx5100 fel and back hoe with his 3/4 ton dodge ram and he goes all over places.
   / How much does a Kubota mx 5200 weigh? #9
My manual states the FEL weighs:
Loader 1,300
Bucket 397 lbs (HD round back)
2013 Ford E-250 Animal Cargo Control Van (A48081)
2013 Ford E-250...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
Auger with Extension (A50860)
Auger with...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2013 Hyundai Veloster Hatchback (A48082)
2013 Hyundai...
2014 Ford F-250 Knapheide Service Truck (A48081)
2014 Ford F-250...
