fifth wheel and gooseneck hitch questions
   / fifth wheel and gooseneck hitch questions #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I just added another truck to serve mainly as the camper hauler (31' travel trailer). New truck is a 4wd, 2006 F350 Lariat crew cab long bed dually with 6.0 diesel (has 83k miles). My questions are there was a hole cut in the bed for a ball mount but the mount is gone. What is a good option for a hidden style hitch there? I don't own a gooseneck trailer currently but have use of 4 different trailers of various lengths.
2nd question is the truck has rails mounted for a fifth wheel hitch but no hitch came with the truck. The rails look like all my friends that have fifth wheels so are these universal? I have no plans to have a fifth wheel camper anytime soon but would like to know I can help my friends if ever needed as we go camping together often.
   / fifth wheel and gooseneck hitch questions #4
Look at B and W, they make a flip over goose neck hitch that can also accommodate a 5th wheel when necessary.
   / fifth wheel and gooseneck hitch questions #5
Here's my vote.
Keep the rails. With the rails you can use either a 5th wheel hitch, or a goose neck adapter.
I have a Reese hitch for my f450, and when I am not using it, I swap in a Reese 'the goose'. Adapter. Goes righton the rails, gives you a ggun hitch.
Way easier than a pop up or flip over ball, no dealing with rusted up parts, or periodic lube to keep it all moving.
There are cheaper plates than the goose, I just happened to be at a Reese dealer when my need came up.
I have a pop up ball in my 350, and had one in my dodge 1500. Work great, but mulch or dirt and debris can get in there...
   / fifth wheel and gooseneck hitch questions #6
I have wondered, because I am set up for a 5th wheel.
The trailer for my tractor is flatbed. Eventually I need to upgrade to larger trailer for the newer larger tractor. I have been thinking if I do upgrade, to go with a gooseneck. Reese and Curt make gooseneck plates to fit in-bed rails.
Then I could to our 5th wheel, swap to the gooseneck plate, and tow a gooseneck flatbed for the tractor.
   / fifth wheel and gooseneck hitch questions #7
Every time I put the 5th wheel hitch in, I have to clean under the rails; they get full of dirt/sand/compost/gravel...
   / fifth wheel and gooseneck hitch questions #8
That's what I do, swap whatever to the rails as needed, or nothing at all.
Thanks guys, I didn't know they make a gooseneck adapter for the rails. That would be perfect. Now I will just have to find a nice way to patch the hole in the bed.
   / fifth wheel and gooseneck hitch questions #10
Guy's, how does the 5th-w to GN adapter work?
I thought that the 5th-w are about 10" up above the bed, where the GN's are at bed level. My GN hitch (on the trlr) is adjustable but I don't think it has 10" of adjustment. I haven't checked into it but I thought that you could only go 5th-w to GN with adapters and not the other way. Just curious.
I've used these folks before and they are good to deal with and offer a complete line. I think they are a small family type bus. that has a big business professionalism. Welcome to Weaver Distributing
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
PORTACOOL (A55745)
PORTACOOL (A55745)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
