MF 35 half shaft collars
   / MF 35 half shaft collars #1
rogert5
sussex
MF 35
Hi all
could anyone tell me the correct way to remove the half shaft collars so I can get to the outer seals on my MF 35?
Thank you if you can help.
Roger.
   / MF 35 half shaft collars #2
Hi all
Roger.
Not sure what you mean by half shaft collars.
   / MF 35 half shaft collars #3
:welcome:
To the forum from Northwest Alabama.
   / MF 35 half shaft collars #6
Press them off.
   / MF 35 half shaft collars #7
I use a SHARP air chisel to expand the old collars, then press off the bearing and collar together
Thank you. Job's done. Split the collars easily but had to make up a thick plate to hold the bearing housing safely as there was not enough showing to press against.
John Deere 2440 Tractor (A52384)
John Deere 2440...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
11ft S/A Fuel Tank Trailer Frame (A51692)
11ft S/A Fuel Tank...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
1992 Effer 7600 2S Knuckleboom (A51692)
1992 Effer 7600 2S...
