MF 35 half shaft collars
   / MF 35 half shaft collars #1
rogert5
sussex
MF 35
Hi all
could anyone tell me the correct way to remove the half shaft collars so I can get to the outer seals on my MF 35?
Thank you if you can help.
Roger.
   / MF 35 half shaft collars #2
Hi all
Roger.
Not sure what you mean by half shaft collars.
   / MF 35 half shaft collars #3
:welcome:
To the forum from Northwest Alabama.
   / MF 35 half shaft collars #6
Press them off.
   / MF 35 half shaft collars #7
I use a SHARP air chisel to expand the old collars, then press off the bearing and collar together
Thank you. Job's done. Split the collars easily but had to make up a thick plate to hold the bearing housing safely as there was not enough showing to press against.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2012 FORD 4 DOOR TAURUS (A53426)
2012 FORD 4 DOOR...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
