How much does my truck weigh?
   / How much does my truck weigh? #11
'Curb' weight is usually empty of fuel, coolant and oil. Grain elevator will weigh it or and truck stop with a CAT scale. (You will have to pay at the TS.)
   / How much does my truck weigh? #12
i thought curb weight was full fuel, oil, ect. and included 150lbs for a driver??
   / How much does my truck weigh? #13
From Wikipedia, the free encyclopedia
Curb weight (US English) or kerb weight (UK English) or unladen mass is the total weight of a vehicle with standard equipment, all necessary operating consumables (e.g., motor oil and coolant), a full tank of fuel, while not loaded with either passengers or cargo.
This definition may differ from definitions used by governmental regulatory agencies or other organizations. For example, many European Union manufacturers include the weight of a 75 kilogram driver to follow European Directive 95/48/EC.[1] Additionally, organizations may define curb weight with fixed levels of fuel and other variables to equalize the value for the comparison of different vehicles.
My title and registration doesn't list the gvw. I would hate to bother the busy folks at the grain elevator, they have consolidated with the surrounding towns and keep busy enough without guys like me pestering them. A fellow TBN member PMed me with info from a 2013 model of 6310 lbs. And 3 or 4 of you above said 5800 or so. I guess that's close enough for now. And it is getting easier to say that my dealer may be a little dis-lec-sick (sp) and got his numbers jumbled up.
Thanks for your help
   / How much does my truck weigh? #15
On vehicles designed for the United States market...the GVW can be found on the Vehicle ID Plate...
Subtract the payload rating for curb weight
Where is the ID plate? On the door post? If so, GVW isn't listed there.
It's supposed to be...possibly coded ?
I did find a decal that said to "never exceed passenger and cargo weight of 3069 lbs". If I subtract that number from the GVWR of 9,200 I get 6131. Could that be the actual weight of the truck?
   / How much does my truck weigh? #19
It's really not my bag to say but that does sync with 'LD1's estimation...
Just an off the wall suggestion...
If there is no commercial scales local to you... and you really want to find out for sure...you might check with your closest state trooper office...they usually have portable ways of weighing vehicles...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2014 FREIGHTLINER...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
