Painted iMatch Quick Hitch Installed on Kubota
   / Painted iMatch Quick Hitch Installed on Kubota
Looks nice!
How big is your Brush cutter? Looks huge on your machine.
Its a 6 footer. It looks larger in the pic than it is. :cool:
Looks good, but i don't get the need for the sticker.
Are you gonna make a log skidding attachment to fit the QH?
I made a couple of mods to my QH.
JB.
Do you get any deflection in the QH when you attach it to a trailer with your add-on receiver hitch? :confused:
   / Painted iMatch Quick Hitch Installed on Kubota #13
Not sure what you mean, side to side movement?
I keep my side sway to the minimum, so not alot of side to side movement.
You do have to be aware of uncontrolled 3pt rise from towing with 3pt, like from backing up a hill or braking down a hill, or dumping a heavy trailer etc.
For that I use a chain from the QH to the draw bar.
JB
   / Painted iMatch Quick Hitch Installed on Kubota #14
The sticker tops it off... it's a John Deere product and I want to note that. :thumbsup:
Yes the skidding attachment will the the QH.
Nice mods! :thumbsup:
I use a dedicated 3pt receiver for pulling heavier loads, because I don't want to pull to hard on the top link, which is where the modded hitch wants to pull from.
But for trailer jockying or pull smaller loads the QH hitch is great, able to lift higher off the ground.
JB.
Going to bring this thread back alive since folks are asking about quick hitches. ttt
   / Painted iMatch Quick Hitch Installed on Kubota #16
I've never used a quick hitch but since it puts the implement a few inches farther back do you have any issues with pto shafts getting close to being too short?
Yes if they are close already it may cause issues. I had to extend the shaft tube on my tiller.
2017 Isuzu NPR Crew Cab 14FT Landscape Dump Truck (A50323)
2017 Isuzu NPR...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
AGT Skidlaoder Post Hole Digger (A50774)
AGT Skidlaoder...
