Need 3610 Ford Tractor - CVA fuel pump rebuild kit
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #1
10usdad
Kingsport
Ford 3610
Need to rebuild a leaking throttle and cut-off. Suggestions where to look for CVA fuel pump rebuild kits. Thanks in advance.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #2
Take the part/model number information) off the pump and then google it and you should be able to come up with something.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #3
:welcome:
To the forum from Alabama.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #4
That would be a CAV pump.
All you need is a cover gasket and 4 of a single part number of o-ring. As a New Holland dealership parts manager, I stock those two part numbers, and IIRC what you need would sell at or near $10, maybe less.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #5
Messicks prices are as follows:
Gasket PN is 381771R1 $9.93
o-ring PN 49886 @ $.63 ea.
Before you remove cover completely take note where spring is attached on both ends. I think I've read that there are u-tube video's on the internet on replacing the o-rings
Why is there wires that attach the two nuts that hold the top cover on the CAV fuel pump? What purpose do they serve?
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #7
They are a factory seal that proves nobody has made any adjustments to the fuel delivery rate or other settings. There is a lead seal crimped over the ends of the wire.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #8
welcome to tractor by net you show home city as kingsport if this tn you can call acme diesel in knoxville 865-524-3005 they will need some numbers off your old one good luck
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #9
I did that same job in my dozer - not bad at all. Look at these
https://www.youtube.com/watch?v=AYz0dCQNiVc
http://www.tractorbynet.com/forums/massey-ferguson-classic-vintage/258591-mf-165-knocking-9.html
This is my dozer
The hardest part for me was getting the cutoff lined up with that shepherds hook you can see on the back left. Took me 3 tries. Just don't tighten the nuts to much until you know it is in.
Thank you very much. Great pictures showing procedure! Very much appreciated!
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
TAKEUCHI TL12V-2 SKID STEER (A51246)
TAKEUCHI TL12V-2...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
