1532 Hyrostatic problem/question.
   / 1532 Hyrostatic problem/question.
I checked relief psi today. Only about 1900. Adjusted to around 2400. I was using my neighbors gauge that god only knows how old it was. I ordered a new gauge today and when I get that in I am going to dial it in. Now the tractor is like every other CUT I have ever drove, runs out of traction before power. I am very happy with the results. Thanks for the help.
   / 1532 Hyrostatic problem/question. #22
Was it the same relief valve that I detailed?
   / 1532 Hyrostatic problem/question. #23
Hmmm... My Kioti workshop manual say 4975 psi.. Our tractor sizes are similiar I would expect something over 4000 PSI. Where and what did you measure? You do know we are not talking about the implement hydraulic pump, but the Hydrostatic drive pump itself. There is usually a special port on the side of the transmission to measure this hi pressure. This is also not to be confused with the charge pump pressure, that is usually a few hundred, Mine is 255 psi. I am assuming you have a workshop manual for this machine. I would not attempt it without it. You say you notice and improvement, but I am a bit confused at the pressures you quoted. I though all hydro trannies operated in this 4000+ area, and the larger they get the higher the pressure. But I could be wrong, I have been before.:)
Yes, I found that that relief valve takes care of the whole system, but I did see another one on the 3 point. I had to break the paint like you explained in your thread. I took the valve out, cleaned it up and started at 0 psi. When the screw was all the way out, nothing worked.
   / 1532 Hyrostatic problem/question. #25
The overall system pressure on my Massey is supposed to be around 2500 ... I'll have to check the manual for specifics but it's definitely not 4000 !
   / 1532 Hyrostatic problem/question. #26
My DK is 4975 psi.
I measured at the FEL output like TSO described in his thread about checking the psi at the loader. On the Massey, it looks to me that one pump is for the system, and one for steering. If you follow the lines, it goes from the pump, to the relief valve. Then a line runs off this to the HST. The FEL valve is piggybacked on the relief valve block(I don't know the technical term for this and I am just calling it like I see it), and I am sure there is some internal passages to get the the fluid where it needs to go.
   / 1532 Hyrostatic problem/question. #28
I just don't see how changing the relief pressure on the implement pump has anything to do with setting the relief pressure of the Hydrostatic transmission. I agree that the implement pump has two sections, one for the FEL/3pt/remotes. And one section for the power steering.. But neither has anything to do with the Hydrostatic transmission relief valve. or its pressure, which for that size tractor would be well over 4000 psi. near 5000.
   / 1532 Hyrostatic problem/question. #29
I haven't been on this post for awhile. I think you are correct on that pressure. I had loader/three point hitch issues when I first got my tractor and it was due to incorrect pressure relieve valve setting on the loader valve. I watched the guy doing it and it was between 2400-2500 when he shimmed up the valve. I'll have to try and find that link for that hydrostatic relief valve for future reference as mine seems a little sluggish but not horrible.
   / 1532 Hyrostatic problem/question. #30
We are discussing two different things.. Yes I can easily believe the 2500 for your implement hydraulic pump. I think mine on the Kioti is about 2645 or something similar. But I was talking about the Hydrostatic transmission pump relief pressure, which I believe should be just under 5000 psi. Mine is stated to be 4975 psi in the workshop manual.
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2019 Ford F150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F150 4x4...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
