Just bought 6110 used tractor moves very slow and loader barly lifts
   / Just bought 6110 used tractor moves very slow and loader barly lifts #11
Oh and check your hyd. level and change the filter
suprisingly enough the dealer is going to fully cover it under waranty!
   / Just bought 6110 used tractor moves very slow and loader barly lifts #13
Great news. Kinda surprised the dealer did not notice it when moving around the lot.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #14
Good deal! I just saw you said it was a repo so most likely the dealer had no idea. Guy knew it was coming and decided run it to the ground I bet. Always good to have a good dealer in any brand
   / Just bought 6110 used tractor moves very slow and loader barly lifts #15
It can happen quick and moving it around here and there wont show much...
Well got the tractor back today and it pulls great now! Clutch was toast obviously. Now on to the hydraulics we were hoping the filter chang might help but of course it didn't help a bit. The fluid looks good but it is very slow or won't even move at all unless you Rev the engine way up also the 3 point hitch is operating just as slow and week as the loader.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #17
Good to hear the clutch is fixed, they didn't look at the hydraulics?
   / Just bought 6110 used tractor moves very slow and loader barly lifts #18
Your rear remote hyd. lever is not engaged is it? It will look to be in Neutral but actually be engaged...
Also did yall replace the strainer filter at the bottom of the transmission?
Your valve is all the way open or not stuck?
You can have them pressure test it by hooking up a tool to the rear remotes and be sure its not the pump.
My dad was the one who took it down there and they were supposedly really busy. I guess he was just happy the clutch was getting fixed even though the waranty was out buy a little bit on it so he probably didn't wanna make a big deal about it since they worked him on it to fix the clutch. I tried moving the remote leaver up nutral and down. It makes no difference but I can hear the engine bog a little bit if you apply it so I know it's turning off in nuetral.
I suppose it's just gonna have to go back down there.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #20
If you hear the tractor lug then it should have good pressure... im wondering if somehow its getting air in the lines (which is strange cuz it should be leaking) or if the the strainer at the bottom of the transmission is clogged. Is it affecting the power steering? sorry if I already asked
(6) Goodyear 8.25 R20 Tires (A51573)
(6) Goodyear 8.25...
2014 Dodge Charger (A52377)
2014 Dodge Charger...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
