Just bought 6110 used tractor moves very slow and loader barly lifts
   / Just bought 6110 used tractor moves very slow and loader barly lifts
Not sure about a strainer, there is a filter right below the door on the right hand side in front of the rear tire we changed .
not sure about any valve being open or stuck?
There is a valve below the seat but it seems to only adjust how fast the 3 point hitch drops.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #22
My bad the suction filter got taken off after the 7110
   / Just bought 6110 used tractor moves very slow and loader barly lifts #23
Were are you checkin the oil at? It should be very hard to see since it is nearly clear
the only dipstick I can find is on the rear diff, and yes it is VERY hard to see because its so clear.
Its not sucking air or at least its not whining like it has air in it and the fluid level is within range.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #25
Do you have an owner's manual that might list trouble shooting ideas? You could also call, or better visit the parts and shop guys. Ask for ideas and make sure you don't have a sump screen. The parts guy would know that and the reason it's been mentioned is because that's what the problem feels like.
my dad decided to just call the dealer back and looks like we will be loading it back up and dropping it off tomarrow again lol. Pulling it with a 1/2 ton silverado and a 30ft gooseneck is no fun but hopefully this will be the last time for a while.
   / Just bought 6110 used tractor moves very slow and loader barly lifts #27
Any updates on this?
Still waiting on a call from the dealer, I will post back once we get it home and make sure it's doing good.
Well took a little while but they ended up replacing the hydraulic pump. It was only putting out around 500psi they told me it should have been around 2500. Now with new clutch and new pump everything works like a new tractor!
Oh yea they also covered that under waranty also!!! Highly recommend mahindra for customer service
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
