PTO remove and replace
   / PTO remove and replace #1
rspatty
ely nevada
Mf 203
I have a MF 203 and the PTO shaft is leaking I need to know how to remove the PTO shaft I have the front cover off that the seal sits. Any help is welcome.
   / PTO remove and replace #2
:welcome:
To the forum from Alabama. Do you have a WSM for your tractor? Not a small job.
i have a reprint manual but its no help
   / PTO remove and replace #4
   / PTO remove and replace #6
G'day rspatty.
Drain the transmission oil ,all of it, put a bolt through the hole in the pto shaft and use a pry bar to pull the shaft and seal out strip the seal housing replace the seal, AND the "o" ring whack it back together and fill with oil should be good for another twenty years.
Happy days.
Hutch.
1964 Mercedes-Benz 190D Collectible Car Sedan (A51694)
1964 Mercedes-Benz...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
1998 Todco 53 ft. Van Trailer (A53117)
1998 Todco 53 ft...
1472 (A51247)
1472 (A51247)
DESK (A53843)
DESK (A53843)
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
