PTO remove and replace
   / PTO remove and replace #1
rspatty
ely nevada
Mf 203
I have a MF 203 and the PTO shaft is leaking I need to know how to remove the PTO shaft I have the front cover off that the seal sits. Any help is welcome.
   / PTO remove and replace #2
:welcome:
To the forum from Alabama. Do you have a WSM for your tractor? Not a small job.
i have a reprint manual but its no help
   / PTO remove and replace #4
   / PTO remove and replace #6
G'day rspatty.
Drain the transmission oil ,all of it, put a bolt through the hole in the pto shaft and use a pry bar to pull the shaft and seal out strip the seal housing replace the seal, AND the "o" ring whack it back together and fill with oil should be good for another twenty years.
Happy days.
Hutch.
Truck Bed (A53117)
Truck Bed (A53117)
International 574D Tractor (A53117)
International 574D...
2018 John Deere 325G (A47477)
2018 John Deere...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
