Impact screw drivers?
   / Impact screw drivers? #161
The Ryobi's work fine, and if the rest tested better. I would not worry about which has the most power. Because they all are apparently pretty good.
Pick a budget, and pick a color. :thumbsup:
Exactly, even the worst of them are awesome.
This one upmanship has no end in site :laughing:
   / Impact screw drivers? #164
The dewalt "20v Max*" are still 18v cells which is misleading at best. *maximum initial battery voltage (measured without a working load) is 20 volts. Nominal voltage is 18 taken off the fine print on my DCG412B box
I was just referring to them as they're marketed....looks like at least three or four companies are selling what they call 20V setups.
I honestly don't care if they put out any additional torque, but they do seem to be lighter, and have longer run times, both of which are nice improvements. Our work 18V DeWalt setups are significantly heavier (and bulkier) than my "20V" DeWalt systems. I actually bought the matching sawzall after reading so many positive reviews....was really hesitant to go cordless, but it's been a total beast.
I've been thinking about getting a 1.5 or 2AH battery because the lighter weight might be nice when you're on a ladder (or walking between trusses the way I have been lately), and I just saw they came out with a 6AH battery that doesn't look much bigger than the 4AH...at least they're putting out products that seem to get better.
   / Impact screw drivers? #166
<img src="http://www.tractorbynet.com/forums/files/projects/410730-impact-screw-drivers-batt4-jpg"/>
12 volt drivers are sooooooo 2004. :)
Sent from my iPad using TractorByNet
   / Impact screw drivers? #168
<img src="http://www.tractorbynet.com/forums/files/projects/410754-impact-screw-drivers-batt5-jpg"/>
Ok, 24 volts! MUCH BETTER! More Power!
   / Impact screw drivers? #169
So two 80 amp hour battery's in series for 24 volts.. Yep that would drive some screws alright.:D
   / Impact screw drivers? #170
At some point, it gets big enough, you may as well go back to having a cord. :yes:
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2023 JOHN DEERE 6R 145 LOT IDENTIFIER 245 (A53084)
2023 JOHN DEERE 6R...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
