Kubota RTV 900/1100 owners READ THIS !!!
   / Kubota RTV 900/1100 owners READ THIS !!! #11
Good grief, that response from Kubota does look like wheel lug nuts...I saw "wheel mounting screw" (singular) and assumed they were referring to the axle nut... I specifically asked about a technical service bulletin on the axle torque...I'da thought they'd look for related service bulletins... :rolleyes:
On a related subject, how do you guys measure 140 ft lbs of torque? I don't have a torque wrench that goes that high, and most of the wrenches I see go to ~150. Do you just torque it to the max and assume it's accurate at the end of its scale?
Thanks,
- djb
   / Kubota RTV 900/1100 owners READ THIS !!! #12
You will need to buy a 1/2" torque wrench. Mine goes to 175 ftlb. They sell a fairly inexpensive one at home depot.
I checked mine (2012 RTV900) and they were fine. I don't know if its standard but mine had a pretty stout lock washer in addition to the castle nut. They were also marked with paint to indicate if they moved.
Thanks,
- djb
I bought this torque wrench off amazon for $59 bucks shipped.Tekton # 24340 is 1/2 drive with 25-250 foot pounds.Comes with case,decent quality wrench for the back yard mechanic.
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2006 John 4 x 4 cart (A50324)
2006 John 4 x 4...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
