Reloading ammo
   / Reloading ammo #151
I dunno, I think I'd strip the 12g stuff too if the diff is 1.25/#
I would do it while watching TV.. Yes, it is mindless work to strip wire, but so is watching TV:D
   / Reloading ammo #152
Im just too dang lazy. The majority of my wire was #10 and above. My stripping machine works great on stranded but not so good with solid wire.
   / Reloading ammo #153
Where do you get your scrap copper wire? We get ours from the left over bits on alarm installations, so it's all small stuff - though there's a lot of it, as we mostly installed "hard wired" systems rather than wireless - better for the customer. Some of those alarm installations are protecting school buildings and their roofs, where the bad guys like to pull wiring out of conduit, for HVAC etc. For the staggering amount of damage they do (which is paid for by the taxpayers of course), compared to the relatively paltry amount they get for copper scrap, they should ought'a be shot on sight. And to steer this back towards topic, reloads should be okay to use for that :c).
im an electrical contractor. This is leftover from jobs. Some real large stuff too. Last time i stripped wire i made over $1,400.
   / Reloading ammo #154
Solid is easy to strip. Get and end and peel
   / Reloading ammo #156
My Hornady press cover came. its sized to fit unit with auto case feeder installed. worked great. has velcro strips in back to get around all wiring. now i don't have to dissemble the entire press and store it between uses. These progressive presses have lots of parts to say the least.
   / Reloading ammo #157
View attachment 411029 View attachment 411030
Very nice. You just reminded me that I need to call them and see if they make one that will do the bullet & case feeder. I didn't see a solution for that in their catalog.
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
