Hobart Handler 140 MIG Welder
   / Hobart Handler 140 MIG Welder #11
   / Hobart Handler 140 MIG Welder #12
The problem with getting the HH140 is that this will start............. and there are No pills for this...<img src="http://www.tractorbynet.com/forums/files/welding/411364-hobart-handler-140-mig-welder-ok-view-jpg"/>
Not true. There are pills that will stop it, but unfortunately you won't be around to enjoy your tools. :(
Terry
   / Hobart Handler 140 MIG Welder #13
The problem with getting the HH140 is that this will start............. and there are No pills for this...View attachment 411364
That's so funny & TRUE!! I got along for 30 yrs. without a welder just fine, but I bought a tractor, then some attachments, then a stick welder, then a dry-cut saw to cut steel, then 2 welding helmets, grinders, respirators, gloves, shields, carts, cables, stingers, ext. cord,welding blankets, clamps, cheap welding table, and some other stuff I can't even think of, all in the last 1.5 yrs.;)
   / Hobart Handler 140 MIG Welder #14
Gentlement, this isn't a disease - it's a BLESSING. (Disease is running out of money before you run out of toys to acquire, or space to put 'em) :D:D:D...Steve
   / Hobart Handler 140 MIG Welder #15
Is it even possible to run out of toys to acquire???!!! Crazy talk,Steve. :) Terry
   / Hobart Handler 140 MIG Welder #16
Yes, the S6 wire is very common. Should be available just about anywhere welding supplies are sold.
I am glad to see positive reviews, I did not know about switching the polarity of the machine when using gas, Thanks.
The ER70S6 wire is that wire a common wire?
   / Hobart Handler 140 MIG Welder #17
If you're going to spring for the welder, spring for the gas. Get the largest bottle you can load/cart to/from the supplier. You won't regret it.
   / Hobart Handler 140 MIG Welder #18
I have the 140 and it's a decent machine, as long as you respect it's limits. Every once in a while, I run into a problem around the homestead that I can't tackle with it, but never anything that costs enough to hire out to justify stepping up to a bigger machine. I like the fact that I can plug it into a standard outlet or extension cord and boogie...and as has been stated, go for the gas...cheaper to run solid wire. Keep a roll of flux core on hand for outside on a windy day, and you'll be good to go.
I am going to set up the welder with gas per the suggestions, will get a bottle, so I should get it filled with 100% argon or the mix?
Also how do I transport the bottle? on its side ok?
   / Hobart Handler 140 MIG Welder #20
You will want a bottle of 100% CO2, or a bottle of 75% argon & 25% CO2.
I lay all my bottles on there side, except my acetylene bottle.
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
HAMM HD14i SMOOTH DBL DRUM ROLLER (A52707)
HAMM HD14i SMOOTH...
2025 Spirit 48V 1000W All Terrain Electric Bicycle (A55853)
2025 Spirit 48V...
