This plow out was a little more expensive
   / This plow out was a little more expensive #11
arrow, did you have a backhoe on your machine.
   / This plow out was a little more expensive #12
A tracked 'dozer on bedrock acts about the same way as a tractor on ice
Both stain your shorts.
Does the same thing on ice if there are no caulks welded on the grousers.
   / This plow out was a little more expensive #13
Of course, coming back through his woods, I ran over something sharp, and by the time I got home I had a flat front tire. There's a moral there somewhere.
No good deed goes unpunished. :D
Arrow, sorry to hear about your mishap, but hey at least you got your machine back, even though the recovery did cost you some bucks.
   / This plow out was a little more expensive #14
Subscribed for future pictures
Not certain what you mean by this LD but if you did sumpin for me to load pics... thanks. After my stuff would not get her out, I succumbed to the 10* weather and just called the service in. Being a Sunday may have caused increased prices but, what the hey. At any rate, there is another 18" of snow under the right wheel of the tractor. Every time I moved, she sunk deeper on that side. It was getting tippy at this point. What might have worked was to lash a pole or 2 by to the right wheel and see if she would work herself out. Perhaps it was the cold and my gloved fingers falling off at this point ( getta get better gloves) but I simply rationed that a wrecker would make this child's play and it did. Perhaps one of those 5 ton come-alongs would have done the job as well. These are before (stuck) and after (on the landing)pictures. As everyone can plainly see, she looks a bit embarrassed that she couldn't get out. Had to console her a bit.
   / This plow out was a little more expensive #16
Nope I didnt do anything. Just wanted to reply so I was subscribed so I could see the pictures whenever you uploaded them.
You were sure stuck allright. Been in situations like that many times. But I usually dont know when to quit and make things lots worse:laughing:
Glad you were not hurt. But I am looking forward to seeing the pics.
Thanks Tman and James for your sentiments. As you can see above, was able to load them up today.
   / This plow out was a little more expensive #19
That's why i leave my backhoe on.
Cheers.
I just mounted mine back on for ballast on Sunday. I have drop-offs like that on both sides of my driveway going down into water. I think I'll leave it on for the rest of the season after seeing those pictures.
Used to get stuck routinely in the old IH, but having a 10' truck plow mounted in a snow bucket with power-down meant I could hinge myself out of a lot of precarious situations, even with a 2wd tractor. Don't think I could of gotten out of that situation though.
   / This plow out was a little more expensive #20
Wow, quite the adventure there Arrow... glad you came out of it unharmed and your "girl" looks to be unscathed as well (less the blow to her ego).
Any idea what set you off in the wrong direction?
-J
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
2014 Ford Escape (A50324)
2014 Ford Escape...
