Chains for a EMax 25 Mahiindra
   / Chains for a EMax 25 Mahiindra #1
BigTee
Member
Kentucky
Mahindra eMax 25
Looking to put chains on my EMax 25, just wondered what is the best chains? I searched the net and didn't find anything to match my tire size. Rear tires are 27x12.5-15
   / Chains for a EMax 25 Mahiindra #2
while not listed specificly, anything that is close to the size but larger will work. You can either take a link out or just use tensioners (as you should use them anyway)
29-12-15 Tire Chains
Thanks, just ordered a set with the tensioners.
   / Chains for a EMax 25 Mahiindra #4
Not sure which tire you have, but i have the Ind tire and i had to remove the tensioners from my chains. They would hold the chain up inbetween the lug of the tire, causing snow to cake in/around the chain defeating the purpose. In another thread a member suggested i try to remove the tensioners and let the chains fall naturally to the ground. This improved my traction DRASTICALLY.
Also, i know you've already ordered... but 2link chains are the way to go.
I also used the 29-12-15 size chain for my Max25
-J
I did order the 2 link chains. Thanks for the info on the tensioners. I would really like to get a blade for the front of my EMax and I could get some good weight on the back.
   / Chains for a EMax 25 Mahiindra #6
I find that weight on the Max provides more traction than anything else. Of course chains are a huge help.
I see you're in Kentucky, so unsure if you see alot of snow down your way. Normally I would suggest a snow-blower vs the blade, but that's all dependent on the amount of snow you get per storm, and the frequency. You can also consider a rear 3pt blade for snow removal, that's what i used my first season. Nice because it's dual purpose come summer, and you get to leave your bucket on. :2cents:
-J
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
Holden Heavy Haul Lowboy T/A Equipment Trailer (A49461)
Holden Heavy Haul...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
1990 Ingersoll...
