dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,679
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Ive checked this stuff out. Thank you.
Im to the point where it must be a relief valve in the steering motor itself.. There's nothing left
Well, there is another possibility: worn piston seal on the steering hyd cylinder. To get adequate
steering force, you need more flow than you get at low engine speeds. How many hours on
your tractor?
As I recall, there are 2 different setups for the steering cyl. Early 4300s have a 2-sided cylinder with
a rod sticking out both sides. Later ones had a more conventional cylinder.
Sadly, some of these JD steering cylinders use welded-on caps and have to be cut open to rebuild.
If you have the conventional cyl, consider replacing it with a modified generic unit.
On both of my 4300s, I did not open the cyls. Here is a photo of how we replaced the cyl on
a 955 with a generic unit.
