Old flail mower
   / Old flail mower
Do the knives look like any of these.
Cup & Scoop Knifes
Lundell is still in business, just a different line now. A member on another site says he bought replacement knives from them a few years ago. It's worth a call to see if parts are available.
lundellmfg
Here is a closer picture than I had in the OP, it shows they are very much a 'T' shape.
Almost looks like sickle sections welded onto bar stock.
Mr. HE:cool:
   / Old flail mower
So...
The labels said 'PATENT PENDING'
Mr. HE:cool:
   / Old flail mower #13
If you can get new knives/hammer knives you should be sitting pretty after you change the
gearbox oil and grease the bearings-no more than 6 pumps in the rotor bearings-the part
the knives hang on and 3-5 pumps in the other bearings every 8 hours of operation.
When you buy it I will welcome you as the newest member of the Flail Mower Nation.
   / Old flail mower #14
GE914-P - $3.43 : Hard Hitter, Wear Parts With Muscle
These blades are 7 3/16 long and 3/16 thick. You could run two on each hanger (total of 3/8 inch thickness and two blades is normal for this type blade) and I think it would work out. I haven't found a "T" type blade like are on the machine now.
Hmm, wonder what size your mounting holes are.
   / Old flail mower
My friend bought it, I'll pass along your welcome and advice. He's pretty good with machines so I believe it is in good hands.
Mr. HE:cool:
   / Old flail mower
Those might work. Right now it has 1/2" grade 8 bolts with a 1/4" bushing around it and holes in the blades are 1"
We are thinking somebody might have made these blades, the mounting tabs are 7/8" apart and there are no washers on the sides to keep them centered. It would be nice to find some pictures of other units made by Lundell, but so far no luck in finding any.
Mr. HE:cool:
   / Old flail mower
Just a quick progress update.
Bolts to hold the blades turned out to be 9/16" once we got them out and measured properly. All new bolts were ordered, grade 8, with lock nuts and washers.
New blades have been ordered, ended up going with sideslicers that match the size very well from cleancutter. Old 'T' blades are going away.
I'm supposed to go over this weekend to work on it, getting it ready for all the parts coming in next week.
Mr. HE:cool:
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
CONTACT INFO (A53084)
2017 Ford F550 Service Truck (A53422)
2017 Ford F550...
2014 KENWORTH T800 KILL TRUCK (A53843)
2014 KENWORTH T800...
