Disc size guess?
   / Disc size guess? #11
I am pretty sure the drawbar HP and PTO HP are close enough to pull a 10' disc. COME ON ITS A DISC:banghead::banghead:
   / Disc size guess? #12
So is that PTO HP, or drawbar HP? Unfortunately they don't publish drawbar HP much these days, at least in the size we're talking about.
University of Nebraska - Lincoln has done field trials on lots of tractors. Almost every ag tractor has been tested and a good smattering of smaller units. Not all tests list drawbar HP, but some do. I did notice on Kubota similar in size that had drawbar HP listed.
Nebraska Tractor Test Reports | Nebraska Tractor Test Laboratory | University of Nebraska-Lincoln
   / Disc size guess? #13
PTO -- the fact sheet says the "(s)oil condition factors are used to convert drawbar horsepower to PTO horsepower."
Steve
   / Disc size guess? #14
Have Kubota M6040 4x4 with loader. Have sandy soil, I think it would pull a 10 or 12' wheeled disc. Hard to find 10' in my area. Im referring to a finishing tandem disc. Off set pulls harder. Any experiences or thoughts?
I bought an old 14 ft wheel disc for $600. Made by Krause. Cut the axles down to make a 9-ft wide disc that I pulled with my Mahindra 5525 (55 hp engine). Worked like a charm in my soil.
Good luck
   / Disc size guess? #15
Good job Flusher. You ended up with a very heavy duty disc for it's size. And you created a size that worked best for you. :)
   / Disc size guess? #16
   / Disc size guess? #17
View attachment 413918View attachment 413919
Good luck
If I recall you're out of farming now, so it's probably not an option, but maybe someone else reading this can try it. In that situation, you could buy the 14' disc for $600, cut it down to 9' for your uses, and weld up the rest as a 4-5' disc for someone with an ATV for SCUT. Probably sell it to them for $600 on a good day.:D
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52128)
Heavy-Duty...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
