Best Marker for Freehand Plasma Cutting
   / Best Marker for Freehand Plasma Cutting #11
Dan, can I get one of those at an auto parts store or do I need to go to a Welding Supply shop?? Thanks for the tip!!!
I can get them at my LWS, but I have also gotten them at MSC ind. supply(MSCdirect.com).
   / Best Marker for Freehand Plasma Cutting #12
Thanks for the tip Dan. Gettin me some of them.
   / Best Marker for Freehand Plasma Cutting #13
I like a sharpie. Silver or black depending on the surface color.
   / Best Marker for Freehand Plasma Cutting #14
   / Best Marker for Freehand Plasma Cutting #15
   / Best Marker for Freehand Plasma Cutting #16
Did you try a lighter lens shade ( lower number)?
Terry
Yep. Learned that trick from a member here on TBN. Helped but still can't see them. Maybe my eyes are just junk. I wear reading glasses and use them when welding or cutting.
   / Best Marker for Freehand Plasma Cutting #17
I have had excellent luck with the White Paint Pen, that Harbor Freight carries....
quick search on their site only shows yellow, but I have purchased both at the store.
Industrial Fiber Tip Marker
   / Best Marker for Freehand Plasma Cutting #18
I spray a very thin layer of high temp flat black paint then draw with a silver pencil and it shows up very well.
   / Best Marker for Freehand Plasma Cutting #19
Where room allows use wooden templets.
Cutting the patterns in wood allows you to see what it will look like and allows more control.
   / Best Marker for Freehand Plasma Cutting #20
I must have missed something here. You use wood as a guide for the plasma cutter??
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
5004 (A55851)
5004 (A55851)
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
