Best Marker for Freehand Plasma Cutting
   / Best Marker for Freehand Plasma Cutting #11
Dan, can I get one of those at an auto parts store or do I need to go to a Welding Supply shop?? Thanks for the tip!!!
I can get them at my LWS, but I have also gotten them at MSC ind. supply(MSCdirect.com).
   / Best Marker for Freehand Plasma Cutting #12
Thanks for the tip Dan. Gettin me some of them.
   / Best Marker for Freehand Plasma Cutting #13
I like a sharpie. Silver or black depending on the surface color.
   / Best Marker for Freehand Plasma Cutting #14
   / Best Marker for Freehand Plasma Cutting #15
   / Best Marker for Freehand Plasma Cutting #16
Did you try a lighter lens shade ( lower number)?
Terry
Yep. Learned that trick from a member here on TBN. Helped but still can't see them. Maybe my eyes are just junk. I wear reading glasses and use them when welding or cutting.
   / Best Marker for Freehand Plasma Cutting #17
I have had excellent luck with the White Paint Pen, that Harbor Freight carries....
quick search on their site only shows yellow, but I have purchased both at the store.
Industrial Fiber Tip Marker
   / Best Marker for Freehand Plasma Cutting #18
I spray a very thin layer of high temp flat black paint then draw with a silver pencil and it shows up very well.
   / Best Marker for Freehand Plasma Cutting #19
Where room allows use wooden templets.
Cutting the patterns in wood allows you to see what it will look like and allows more control.
   / Best Marker for Freehand Plasma Cutting #20
I must have missed something here. You use wood as a guide for the plasma cutter??
2020 Deere 50G (A53317)
2020 Deere 50G...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
Nissan Forklift (A55973)
Nissan Forklift...
push mower (A55973)
push mower (A55973)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55315)
Michelin CARGOXBIB...
Root Rake Attachment (A56857)
Root Rake...
