weld qa plate to bucket
   / weld qa plate to bucket #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Is a Hobart 210 mvp too small a machine to weld a quick attach plate to a front end bucket?
   / weld qa plate to bucket #2
It is rated to weld 3/8". Aren't your plates 3/4"?
plate didn't look that thick. I will have to go measure it. Thanks
here is the spec from the first weld on plate I found - still don't know if my welder will safely handle it.
•Constructed of 1/4" Grade 50 steel with a 3/8" thick Top Bar
   / weld qa plate to bucket #5
A well burnt in three pass would be acceptable in my book. Are you running hard wire or flux core?
   / weld qa plate to bucket #6
If you're having doubts about the capacity of your welder, here are a few things to consider doing.
Bevel the quick attach plate.
Preheat the weld zones after tacking everything up, just before welding.
Use 100% CO2 gas, with Lincoln's L-56 wire.
Use Lincoln's NR-212 self shielded wire.
Weld everything vertical up hill.
I have been using flux core but looking at Shield Arcs suggestion i will get some Lincoln's NR-212 which i think is also flux core.
is that .45 only or does it come in different sizes?
   / weld qa plate to bucket #9
I think L-56 you can get in .023" or .025", .030", .035", ,045", .052", and 1/16".
NR-212 the smallest I think they sell is .045". You can get .030" in NR-211.
   / weld qa plate to bucket #10
If you have access to both sides of each plate no worries at all. Consider getting some scraps appx same thickness & test your methods. Happy to see Shield Arcs list of tips !
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
