weld qa plate to bucket
   / weld qa plate to bucket
I think L-56 you can get in .023" or .025", .030", .035", ,045", .052", and 1/16".
NR-212 the smallest I think they sell is .045". You can get .030" in NR-211.
I see they have a NR212 3/64 but I don't know what that is or where I would place it in the chart for heat/speed. Seems to calculate to about .040 is that a size? Would I just split it between .035 and .045 if it was?
   / weld qa plate to bucket #12
3/64" could just be a misprint for 5/64" :confused3:
3/64" = .046875"
Too close to .045" to be needed in their inventory in my opinion?
I have no doubts about your welder having the power for the task.
Do you have experience with welding 1/4" and 3/8" material?
3/64" = .046875"
No i do not have the experience yet. Maybe i better hold off until i get more under my belt.
Lincoln Electric Innershield NR-212 3/64 in. Self-Shielded Flux-Cored Welding Wire-ED026090 - The Home Depot
here is where i saw the mig wire I must have converted it wrong
Thanks
   / weld qa plate to bucket #14
Here is what NR-212 looks like.
First picture is flat.
Second picture is vertical up hill.
Third picture is over head.
   / weld qa plate to bucket #15
   / weld qa plate to bucket #16
Consider drilling the qa plate on the flats and then plug weld it as well as doing the edges.
I drilled three 1" (?) holes on either side of mine (5/16" plate) and plugged 'em ... and then ground them smooth so the tractor-side qa would mate with no issues. Lincoln PowerMig 215 ...
Hasn't come loose yet ... :D
   / weld qa plate to bucket #17
Instead of 2 pages, the simple answer is yes... of course you can.
It concerns me that 1) someone thought a QA plate might be 3/4 thick steel and 2) the OP has picked the plate up before and didn't know it wasn't even close to 3/4 :p
   / weld qa plate to bucket #18
Good point. Also 2 pages in and no pics of the project.
   / weld qa plate to bucket #19
In these lengthy discussions many things will be learned. For example did you look as SA's pictures?? Can you weld like that??
I would agree that a person experienced with metal would know the difference in weight of a piece of 1/4" versus 3/4". But for someone trying to learn, maybe not.
I consider myself an average welder. For me, the most important thing is understanding where the stresses are going to be and how to best overcome them. By that I mean using grinding/angling techniques, different welding positions, etc. Last would be my concerns about the Welder's ability. Operator ability comes first. I'll guarantee you SA can weld it on with a much less capable welder than the OP owns. :)
   / weld qa plate to bucket #20
Feasibilty of the project might come first. Without a pic of the project and the parts, forum assistance spirals off into uselessness. Not that pics prevent that, but they make good help "possible". :D
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
