How to keep gooseneck trailer electric cable from getting caught in bumper?
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #11
Plug in the bed.
I pulled my Gn once with the factory plug under the bumper. Next day went to town and bought a plug and play wiring harness with new plug/housing. Drilled a hole in the front of the left rear corner bed upright and installed it. I have no cord dragging or even getting dirt when pulling in bad weather. I also carry a hooked rod that lets me latch/unlatch the hitch without having to climb in the bed. Life is good.
Edit: Here ya go. Took a pic. See how clean? )
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #12
When we towed a GN horse trailer, the plug was on the side of the bed, actually in the plastic bedliner.
Plug in the bed.
That looks great.
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #14
That looks great.
30 minute install. By using a plug/play wiring harness I still have the connector under the bumper. I use it when pulling my Son's bumper hitch trailer. Best of both worlds. :)
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #15
Mine is set up like that as noted in earlier post with links to those harnesses. Works great. And, still have plug by receiver hitch for my other "bumper pull" trailers.
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #16
Out of curiosity, where did you get your plug and play harness at. Drew a blank with my Ford dealer?
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #17
never occured to me that the plug for a GN or 5th wheel wouldnt be in the bed of the truck. only ones ive ever seen were in the bed of the truck on a 3' pigtail.
I think if i only had one 7 pin recepitcal and it was down at the bumper, id build an extension cord to get it up into the bed and connect it up there so these stories dont happen.
After watching the videos on etrailer.com, I think adding a 7-pin plug to the bed might be something I can tackle myself.
Thanks,
Chris
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #19
Thanks,
Chris
I would pretty much bet you could do it yourself. The hardest part is coming up with the proper size hole saw (if you don't already have one).
Drop the tailgate, drill the big hole, feed the wires down, drill the 1/8th holes to screw down the new receptacle, drop the spare tire, unplug your current 7 wire, plug your new one into the circuit, zip tie the excess out of the way, raise the spare tire. Then go get a beverage of choice and sit back looking at how pretty that new receptacle looks back there.
EDIT: I'm pretty sure that after checking out all the online places, Amazon had he best price, etrailer was close and in case you've never ordered from etrailer, they ship almost as quick as Amazon
   / How to keep gooseneck trailer electric cable from getting caught in bumper? #20
That's where I got mine. They actually had it in stock. But I'm in GN land with all the cattle farmers around. They said over half of the diesel 3/4 ton and heavier trucks they sell have them installed before they leave the lot.
2018 New Holland Workmaster 60 4x4 Tractor with Loader (A54865)
2018 New Holland...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2017 BX2680 Sub Compact Utility Tractor (A55314)
2017 BX2680 Sub...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A55745)
2011 FREIGHTLINER...
