White Smoke Jinma 254
   / White Smoke Jinma 254 #1
Jinma284
Lady Lake, Fl.
Jinma 284
When I first start my tractor I get white smoke. What causes that? The smoke starts while cranking and stops almost as soon as the tractor starts.
   / White Smoke Jinma 254 #2
usually water in the fuel...
   / White Smoke Jinma 254 #3
White smoke is unburned fuel. You may have a slightly dribbling injector.
   / White Smoke Jinma 254 #4
White smoke can also mean a lean condition, check to make sure your fuel filter isn't getting plugged.
SR
   / White Smoke Jinma 254 #5
it is kind of normal when cranking to get white smoke, it is the cylinders just starting to fire but not quite enough heat, compression or some low fuel pressure till it all comes up and hits...
M
   / White Smoke Jinma 254 #7
If I don't plug in my tractor on a cold morning I get whitish/greyish smoke for a couple minutes but if I plug it in I get no smoke. This would lead me to believe that what STRIKER posted is the possible cause. I wouldn't worry about it.
   / White Smoke Jinma 254 #8
How does that work? Please explain
White smoke can mean a "leaned out" condition... A plugged or nearly plugged fuel filter will cause a leaned out condition... (not enough fuel getting through the filter)
It's another thing to check, NOT the only thing that can cause white smoke...
SR
   / White Smoke Jinma 254 #9
SR
I think what he meant was (and I am also curious as well) why a lean out condition results in a white smoke?
Also it is possible that a coolant leak via the head gasket could be causing this?
   / White Smoke Jinma 254 #10
There's a joke to be made there, but I won't make it.
Okay, yes I will.
They make pills to cure a "dribbling injector."
2007 STERLING A9500 DAY CAB (A56129)
2007 STERLING...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
John Deere Turf Gator (RUNS) (A50775)
John Deere Turf...
2010 Honda Insight Hatchback Sedan (A55758)
2010 Honda Insight...
2014 Ford F-150XL (A53314)
2014 Ford F-150XL...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
