Homemade trencher digging a ditch for cables
   / Homemade trencher digging a ditch for cables #1
tractorgp
Newfoundland
Kubota BX25
Earlier I posted a video on how to setup the homemade trencher on the tractor bucket http://youtu.be/nh_mYjWfJeY. I found this "new" footage while working on another video related to installing a security camera. This video shows the trencher getting bent up going through the rough ground. I now have a heavier piece of angle on standby for the next trench.
   / Homemade trencher digging a ditch for cables #2
Why not use a subsoiler or middle buster? Looks like it's making a rough cut that will need cleaning up by hand but,if it works for you who am I to judge.
   / Homemade trencher digging a ditch for cables #3
I once had a nice trench dug by a ditch witch, that a 100 ton crane drove closely along before I got my cables installed. A friend had leant me an old JD TLB to which I mounted a piece of channel to the bucket by drilling holes in the hoe bucket (glad I don't have friends like that!). that was just to open the trench, not to make a new one from scratch. I popped those 1/2" bolts off like they were nothing. Seems I seriously underestimated the forces involved.
I think I ended up doing most of it by hand. Used a hoe and a steel formed type of box on a handle that I scaped the dirt into and removed from the trench.
It's not something I do everyday and this rig is basically free, easy to set up, and actually fun to use :)
Lots of forces involved for sure - you can see those rocks "smoking" all the time but I can tell by the feel that the BX is well within its comfort range :)
   / Homemade trencher digging a ditch for cables #6
Nice.:thumbsup:
   / Homemade trencher digging a ditch for cables #7
Nice job . Looks like it works better than a claw on the backhoe . You have a few rocks there also . Not as many as we have here but this is the " rock " . I bought a post hole digger and a box blade for mine but haven't used it yet . Too many rocks here . I do use the pallet forks I bought all the time . The kubota BX is a good machine .
Before I got the BX I dug fence post holes with a fairly heavy duty rented rig like this one here http://youtu.be/y45iIkkQxWkIt was not much use in digging through the "soil" and rocks. In most all cases I couldn't get down deep enough and most all posts loosened-up. After a big wind storm - some even blew over. After I got the BX I dug down by these weak posts and installed 4x4 struts angled and bolted to the posts. No problem since. Now, as I continue with my fence building I dig down 30-36 inches with the BX and, where necessary, I add portland cement to the backfill for extra solidity.
   / Homemade trencher digging a ditch for cables #9
It amazes me having a backhoe you would still resort to this. It makes a mess, a crappy trench, and puts a tremendous strain on the front end loader in a manner it's not really designed for. If you want to do that, put the angle on a 3-point mount facing forward, at a steeper angle.
Yeah but it works just great :)
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
1998 12ft T/A Park Dump Trailer (A52377)
1998 12ft T/A Park...
