Slow Moving Vehicle triangle reflector sign used as driveway marker?
   / Slow Moving Vehicle triangle reflector sign used as driveway marker? #61
Most of the laws posted here are vehicle laws and specifically state "on the highway".
While that may cover 'ditch markers', these laws still might not pertain to usage on private property (which is often where mailbox posts are located).
   / Slow Moving Vehicle triangle reflector sign used as driveway marker? #62
Actually, mailboxes are generally located in the right of way which is considered part of the highway. That is why the highway department can tell you to replace your railroad tie mailbox post with a 4x4.
Aaron Z
   / Slow Moving Vehicle triangle reflector sign used as driveway marker? #63
Actually, mailboxes are generally located in the right of way which is considered part of the highway. Aaron Z
My apologies, I have never had a mailbox and made a bad assumption. :eek:
   / Slow Moving Vehicle triangle reflector sign used as driveway marker? #64
Agree with Aaron. It's a creative argument, though. A closer question would be where the SMV emblem marking the driveway is set back enough to be off the right of way, but is still clearly visible from the road, as at a bend where the headlights catch it full on just before the road curves. Under the Virginia statute (cited above), I think the sheriff could still write a summons. :)
   / Slow Moving Vehicle triangle reflector sign used as driveway marker? #65
One article I read said you were to remove or cover any SMV emblem on equipment used or parked where it could be seen from the road.
I think that's crazy.
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2006 International 7400 Dump Truck (A47477)
2006 International...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
