bx24 leak at hyd. manifold
   / bx24 leak at hyd. manifold #1
jondog
NEPA
BX25
Hey,been a long time creeper and found much needed info.After this winter heavy snow fall I parked her in the shop and found a drip,later found to be where the down pressure line goes into the manifold.Got to the 26mm nut and found not enough room to lift it out.Do I need to remove the entire line to replace the O ring?,if so it is way tight to get onto the nut between the loader and frame.Remove the battery?Any help guys...thanks..gotta get her online asap.
ok ...more research,cutting a hole in the bottom of the battery box?For an O ring swap,no other takers on this?How about the order numbers for the rings as I will order or pick up before tearing into it
   / bx24 leak at hyd. manifold #3
Sounds like a lot of trouble. Is it a nut ... or bolt head. Was/is it tight. I am not familiar. Do you know theres an oring seal or could it be a copper washer? In any case may be able to stop the seep/leak in place by use of Loctite wicking compound. It will creep into a tight crevice and set up. The leak path is then blocked. You can remove the bolt later if its ever necessary.
larry
Thanks for responding Larry, yes it does sound like a lot of work and I did put some Loctite in there and it seem to stop for now however it is a rubber O-ring I would like to repair it properly and I do appreciate your response thank you
   / bx24 leak at hyd. manifold #5
Are you positive it just didn't need to be retightened? If it's a bad O-ring I can't see Loctite sealing it.
   / bx24 leak at hyd. manifold #6
Wicking Loctite would seal the head of the bolt to its seat, effectively forming a seal beyond the oring.
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
