HF Winch
   / HF Winch #11
I just bought one of those myself, but haven't hooked it up yet. The big one seemed to be the best deal, and I thought "why not, might as well get the big one in case I need it". I started having second thoughts as soon as I went to get it off the shelf, that thing is heavy. I had ideas on moving it around from the front of the truck to the trailer and back, but if I add a quick mount of some sort, that's going to make it even heavier to move.
If you use a snatch block, you can use a smaller winch. So long as you have enough cable.
   / HF Winch #12
I have the 12000# badlands winch, no matter how I try I can't get it to wind back evenly on the spool.
Get the extended warranty, you can get a new one every two years.
   / HF Winch #13
That two years still leaves you without a winch for a year after you burn the first one up in year one.
   / HF Winch #14
I would use Anderson power connectors. They are used on electric fork lifts to connect the battery. They have polarity (+/-)but not gender(M/F). Might be important if there is any electronics in the forward/reverse parts.
I will second CNC Dan. Forklift connectors are the best suited for this application, as well as for boosting cables purposes. 1 gauge wire is just perfect for your application. Check your owners manual, to see if they talk about it.
   / HF Winch #15
Hmm. How do you figure that? :confused: I've never bought the HF extended warranties (and fortunately have never needed them). But if you burned the first winch up in year one in, seems to me they'd replace it right at the store.
   / HF Winch
Could someone double check me on the wiring. The first pic shows the long wire going to the motor and the breaker on the short wire. The parts breakdown calls the long red wire the battery wire and the 3 wires with the rubber jackets motor wire. The first one seems wrong even though it shows the breaker on it. If someone could look at theirs I would appreciate it.
   / HF Winch #17
Something like this? I have a much smaller winch and only use it to pull a car up on trailer. 4 awg wire and 125 amp breaker. Using a breaker is a must! I've seen a couple trucks burn to the ground because there lift gate motor stuck.
It is an Anderson connector you can get a boot for the backside and the rubber cap to protect from water.
   / HF Winch
No not exactly. The directions aren't Real clear to me. The wiring diagram shows the longer red wire going to the motor and the short red wire with the breaker on it. It doesn't seem right. I will take a pic in the morning.
   / HF Winch #20
Get the extended warranty and your protected. If anything goes wrong within two years, bring it back to the store and get a new one.
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
