   / Harbor Freight Tools that don't suck #4,461
That's been my experience as well. I'd love to get one that will work on their sawmill.
Here is one but it is expired:mad: I am going to do some digging and see if I can find one that can be used on predator products. If I come across one that can be used on the saw mill that is valid I'll let you know.
Harbor Freight Coupon Codes January 2015
   / Harbor Freight Tools that don't suck #4,462
I don't do anything special to prevent rust and except for a tad of surface rust, it has not been a problem. My drill press is 900 feet from salt water with the prevailing breeze carrying salt air to my barn most days.
IT;
What do you use to remove the sticky stuff they coat their unpainted parts with?
Sent from my iPad using TractorByNet
   / Harbor Freight Tools that don't suck #4,463
IT;
Sorry don't recall specifically but I would usually think of a little diesel on a rag should do it.
   / Harbor Freight Tools that don't suck #4,464
I have used mineral spirits. Kerosene works also.
To prevent rust on bare steel and cast iron... Johnson's Paste Wax. This can also be used on any machined table top (table saw, drill press, band saw, jointer, etc.) with no danger of messing up your wood for finishing. Don't use automotive waxes as they contain silicone which will get in the wood and ruin the finish.
-jp
   / Harbor Freight Tools that don't suck #4,465
This coupon code should be good for a few days.
20% off everything in cart - usual exemptions - till 3-22
91204098
   / Harbor Freight Tools that don't suck #4,466
91204098
Don, if this is the coupon you mean (it has that same number), it excludes all Predator gas powered items, also the Central Machinery 280 cc gas portable sawmill. Harbor Freight: What Would you do With $100? | Milled
Roger, I have a dozen or so current 20% coupons that I've accumulated, plus some 25% for their upcoming Easter weekend sale, and they all have the Predator exclusion. :(
   / Harbor Freight Tools that don't suck #4,467
IT;
I use Acetone for most all my cleaning. But I also wax bare steel after it has been cleaned well to keep from oxidizing.
   / Harbor Freight Tools that don't suck #4,468
The notable point regarding the HF coupon Don linked is that it is good for 20% off everything in the cart so long as you spend over $100 (minus the usual exclusions). Better than the typical 20% off one item coupon.
   / Harbor Freight Tools that don't suck #4,469
Thanks for checking.
   / Harbor Freight Tools that don't suck #4,470
Yes 3point that is the coupon. It's good if you are going to buy multiple items because of the TOTAL (over $100) not the usual one item only 20% off. (and yes there are exclusions)
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A58017)
2002 WESTERN STAR...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
Hydraulic spike driver (A56435)
Hydraulic spike...
