Calibrating PTO spreaders.
   / Calibrating PTO spreaders. #1
bleeting
here
none
I've read how to do this by doing test runs, using the width and distance spread vs weight spent. I don't really like the idea of wasting a bunch of fertilizer doing this, and 100 times so on expense seed. :eek:
You can fairly quickly, and with little waste, find the effective spreading width with your material. Distance spread is simply a factor of time. So using that why couldn't one just pull the spinning disc off and just let fertilizer drop into a bucket to be weighed.
Example;
50' spreading width
10mph (14.67 feet per second)
=733.5 sqft/s = 1 acre coverage every 59.38 seconds, round up to 1 minute.
Now if you know you need to spread 500# fertilizer per acre, can you not just pull the disc and see which setting drops 500# in a minute (or 250 in 30 seconds, or 50# in 6 seconds). There should be no difference in amount through the gates while actually spreading with the disc or dropping straight down. It's not like the spinning disc causes a backup or slows the rate or anything.
Practical tests are always going to trump, but this should output very close to a practical test, maybe even more accurate since it removes a factor of operator error.
Am I crazy?
   / Calibrating PTO spreaders. #2
What's the difference betw that and a test run? Sounds like the surest way to get an accurate rate.
Jim
Jim
Ever looked at the cost of bahai seed? The difference is wasting hundreds of dollars. Or for fertilizer probably more like 50 or so and not burning out a huge area.
   / Calibrating PTO spreaders. #4
Understand your plight. Have done the same for a number of years. Switched over to a grain drill a couple of years ago and never looked back. Now I use the cone spreader only occasionally. Much easier and way less waste. My seed runs around $500 for a 50# bag.
What do you use, I've been looking at slit seeder/over seeders no till drills etc and they all seem to be 10k+, can't justify that expense for how much I would actually use.
   / Calibrating PTO spreaders. #6
My local feed/seed store will rent a notill drill for a half day for about 250. Might see if yours does that or ask the local farm extension office of they know where to rent one
   / Calibrating PTO spreaders. #7
Example;
50' spreading width
Am I crazy?
The bucket test is the best way to to this as you will know exactly
how much you are spilling through the volume regulating passage
of the spreader in a set time period AT ANY TRAVEL SPEED.
The volume regulating passage is going to dump the material
through it no matter to the travel speed.
So much of this is going to depend on the quality of the material spread
as fertilizer that is dusty with no prills (pellets) is going to drop like a stone
and burn everything.
   / Calibrating PTO spreaders. #8
You must have nice fields if you can spread at 10 mph. I've calibrated salt and sand spreaders using a stop watch and scale but that might not apply to a cone type spreader. Dose engine rpm/ pto speed need to be constant?
I think I'd put one bag in the spreader set on it's next to smallest setting and measure how far that went using the gear and pto speed I wanted then adjust up from there one bag at a time until I got it where I wanted for that material.
   / Calibrating PTO spreaders. #9
PTO speed determines how fast the disk spins & how far it flings stuff. Stuff just falls out of the hole above the disk, so the disk doesn't affect how much falls. Unless its not spinning at all & stuff backs up to the hole.
   / Calibrating PTO spreaders. #10
OK so the pto speed determines the width and the gear selection determines the length and the hole setting determines the lbs/minute? You could vary any one of them to change your application rate and you should change just one at a time to find the right combination. So to simplify the process I'd set the engine to 2400 pto speed for 540 pto rpms then pick a gear that was comfortable on the ground in question and then just adjust the hole opening until I found the right hole size to give me the desired rate.
That is the standard way to do it. Point being, the whole time you're experimenting finding the right opening you're wasting product and potentially burning out wherever you're testing it. My point is knowing spreading width and tractor speed, you know area covered over time. If you also know the weight dispensed over time, it's simple arithmetic to find the right setting from a standstill, more quickly, and without wasting anything.
   / Calibrating PTO spreaders. #12
That's why I suggested at starting at next to the smallest setting which would most likely be too light. material not wasted and you can easily go over the test area again to add more. No way to pick it back up if you start large. These spreaders are pretty simple and I expect they vary quite a bit in output based on the height of the pile inside them so to really test it you would need to have the hopper half full to get the average.
I don't know as the tractor sitting still would shake down material the same as it would moving over the field. Something to test I suppose. Now if you have 500 lbs. in bags sitting there and an acre to do you could just set it light and go over it twice or more in a pattern to double cover things and stop when your 500 lbs is gone and have a pretty even distribution that couldn't be too heavy anywhere.
   / Calibrating PTO spreaders. #13
The light application with multiple passes is my preferred method, helps get a uniform seed bed. ^^^^^
I find it hard to simplify this as different seeds and different fertilizers have various distance of throw and flow out the hopper at different rates. Some of the heavy fertilizers may throw 50 ft while a small seed may be thrown only 15 to 20 ft. Lots of variables so I get out of the seat and check the swath width and density on every job. Since seeding and fertilizing goes so quickly a little more time spent seems to be the best bang for the buck.
Here are some time lapse pics, the field was planted on 9 11 14 the first picture is 9 19 14, the second and third are 9 23 14, forth is 10 15 14, fifth and six are 11 02 14.
   / Calibrating PTO spreaders. #14
Something else I have done before is to use 12" white self stick tile in a few spots in the field. With the adhesive turned up the seeds stick to it and I can take these home and get a good idea of the amount of seed density per square ft.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2013 FORD F250 (A60460)
2013 FORD F250...
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
2018 Toro Groundsmaster 4000D Batwing Commercial Rotary Mower (A59228)
2018 Toro...
