New Member -YM 1700 transmission dipstick length
   / New Member -YM 1700 transmission dipstick length #11
From one 1700 to another-Welcome aboard tgrammar,
my 1700 came with the style that has the stick type,
You mentioned about checking the hyraulic fluid, so I attached a photo of it as well,
with having so many variables between just the 1700's alone it can become confusing, I had always thought the 1700 and 2000 had the same engine and transmission, although I'm begining to question even this now,:confused:
I think sometime along the life of our Yanmars people may change parts using what ever is available and will work,
( guilty as charged ) I couldnt be 100% sure that the dipsticks on my tractor are original, But do know they came on the tractor when I got it,
   / New Member -YM 1700 transmission dipstick length #12
looks very close to the 336 as well.....
   / New Member -YM 1700 transmission dipstick length #13
Looks pretty darn close if you look down at the Standard measurement. The side of your tape is 1'-1/16'. I'm 95% sure mine is Orig. so tgrammer should be okay with these measurements. Another way is in my notes I have 16Qts. 4gal. JD 303. Change the Hyd. fluid and check it and see what happens. They matched mine when I refilled it.
   / New Member -YM 1700 transmission dipstick length #15
Dang it! Those 2 things must have rolled right in there again... Told you 21 it....LOL.....:D
Wow! thanks for all the welcomes and responses!
i just measured 1 3/4" from the top of the hydraulic fluid to the outside(top) surface of the dipstick screw threading which means if i had an 8" dipstick, my oil level would be substantially high.
I think i'll go ahead and change the fluid and see how the two levels differ
   / New Member -YM 1700 transmission dipstick length #17
Time to clean the Filter while you're draining it. 3 bolt triangle plate and you should be in good shape.
Finally getting around to changing the trans fluid.
Took off the 3 bolt triangle plate and the screen is completely gone! Also theres metal shards that i suspect are the remnants of the missing dipstick...
Anyone know where to get a new screen?
Also what else should i check on? right before i started changing the fluid, the 3 pt system completely stopped working. could i have a clog somewhere?
ok just found the screen assembly from Hoye
while i have the fluid drained, what else can i check on for the 3 pt lifting/lowering issues?
further update:
i found and removed the old screen that had sheared off the plate. also removed the spring and rod
i'm currently using a magnet to fish out the shards of dipstick
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
