Time for a new bridge - how to engineer?
   / Time for a new bridge - how to engineer? #21
While the preponderance of the recommendations are for a culvert, my wife really likes the bridge option since that it what has always been there (since her grandparents' day). Local lumber yard has #1 used railroad ties, 7" X 9" X 8'. If I use them as beams, I shouldn't have to worry about rotting, and can afford as many as it would take to make the deck sturdy. One possibility would be to use 4" X 6" X 10' posts for the decking.
Anyone know how I can calculate how many beams I need to carry the load of a small, loaded gravel truck?
Thanks for all the information!
Careful. Those used rail road cross ties are often damaged/rotten/half split. They removed them for a reason. They're good for retaining walls, fence posts, ect; but don't assume 50 years old, half rotten cross ties are equal to new lumber.
I'm not trying to talk you out of a bridge. Just be careful with That plan. Really if you want a bridge, you could do two nice footers on either side, keeping span to say 48"; and use something like 4x6 pt as the deck. Of coarse, do some quick load calcs.
   / Time for a new bridge - how to engineer? #22
I'm personally going to vote against using wood for your bridge beams. you say small truck but that's open to a lot of interpretation. Are we talking a one ton dump that could weigh 15,000lbs or are we talking a tandem that could weigh 54,000lbs? Personally, if your not going to use steel for the main beams, I think your going to have a tough time talking anybody but your friends or yourself into driving over a wooden bridge loaded. Have you looked at getting an old semi trailer?
   / Time for a new bridge - how to engineer? #23
I believe that #1 grade ties are the best of the landscaping grade ties. They are not good enough to be reused as a RR tie. I wouldn't use them for a driveway bridge.
A truck on a tie bridge would be supported by only one or two ties per side. Ties not under the wheels wouldn't make the bridge stronger, on a simple beam bridge design.
Bruce
   / Time for a new bridge - how to engineer? #24
Or a fire truck rushing to your house? Some fire departments or counties will examine private bridges to determine whether they would drive a truck across.
Bruce
   / Time for a new bridge - how to engineer? #25
Here is a link to the standard wood beam table.
www.awc.org/pdf/WSDD/C2B.pdf
You will need to determine the actual clear span you need to bridge. Then you can find the capacity of beams. I usually use Fb=1000 for treated lumber. I vote against the used ties. You have no way to determine actual strength.
As an example, the table says a 2x12 spanning 8 feet will support 2636 lbs. If you want to support 10,000 lbs, you would need 4 of those. You need to design with blocking to keep them from rolling and it's always good to throw in a few extra for safety, given the relatively low price of treated lumber. If the design has the beams relatively close together, you can use 2x lumber for the deck also.
   / Time for a new bridge - how to engineer? #26
The railroad ties are not dimensioned correctly for bridge beams.
   / Time for a new bridge - how to engineer? #27
Farmer next door has a real Mill stream on his place. Mill is long gone but the stream still takes water off the river and runs across his property behind a barn etc. Anyways his grandson starts stockpiling concrete pipe of different sizes,along with a bunch of busted up slabs of old concrete. He ended up with a twelve foot wide crossover. Has withstood the river flooding, and some large loaded logging trucks. The old concrete and steel beams never would have handled the new traffic. Only thing it will see this summer is hay equipment.
   / Time for a new bridge - how to engineer? #28
Bruce
That is very true! Our local FD had a neighbors address 2 parcels away marked as "DO NOT CROSS BRIDGE" on the bulletin board, sure enough the house caught fire, they pulled up to the bridge and started dragging out hose. They were able to keep it from spreading up the hill but the house was a total loss. I will say that the bridge was one that I would be careful about walking over at night in the dark. Here in Santa Cruz Co. a bridge for a residence need to be certified for a minimum of 25 tons for fire trucks.
   / Time for a new bridge - how to engineer? #29
Those load tables assume even loads too.
While a loaded dual tandem truck may be more distributed, the front axle is not. And neither are any single axle trucks.
Personally I would want a minimum "point load" capacity 20T, which would be about 40t worth of distributed loading. (talking full sized trucks and fire trucks etc).
That would require 15 2x12's laminated together on each side under the tire tracks.
The 8x8's the OP first mentioned are good to about 5800# each for a distributed load. So a pair of them would handle most normal auto's up to a 1-ton truck but not loaded.
I wouldnt even trust 2 of them each side for a dump truck.
Have you considered steel beams?
A pretty common and not too heavy beam: W12x26 spanning 8' would be good for 20,000# point loaded in the middle. Add a second for the other tire track and you have a 20T point load and would likely handle anything you could think to drive across it. Including a fully loaded dump truck.
A 20' stick of this beam cut in half giving 1' over each footing, likely would cost ~$500 or so. Possibly add a third beam in the middle to help support some decking (which I wouldnt use 2x lumber. At least 3x or better).
Could also shop c-list. Not sure what it is like in your area, but I often see old beams from demo'd buildings or bridges for a few bucks more than scrap prices
OK, railroad ties are out. Actually the whole idea of re-building the bridge is out. No way I can engineer it for fire trucks and gravel trucks. A culvert is more practical and cost-effective. All the responses have been helpful in making this important decision. Now to plan for a pipe and quarry product.
- JeremyL
   / Time for a new bridge - how to engineer? #31
WE need pictures of the project as it goes along.
Will definitely post pictures of the project, which I hope to do in early April, weather-permitting.
   / Time for a new bridge - how to engineer? #34
   / Time for a new bridge - how to engineer? #35
So whats the plan of attack for this bad boy? Some reading material to help.
A Landowner's Guide to Building Forest Access Roads - Stream Crossing Methods
Little more practical guide than just a bunch of pipe specs. You should be looking at a minimum of 12" of cover and hopefully a 15" pipe or larger based on this guide.
I"d have got to the manual before we got done. ;). Remember that a 12" minimum cover is just that a MINIMUM. Two to three feet is better and reduces stress on the pipe.
Now if we could just have a USGS contour map of the up stream area we could figure out the correct size for the pipe.
   / Time for a new bridge - how to engineer? #36
   / Time for a new bridge - how to engineer? #37
Just keeping an eye on ya! :thumbsup: More cover is definitely better for pipe life. The only problem is your side slopes and the length of pipe that they eat up getting to the driving surface. He will Likely will have to put in double the amount of pipe compared to the actual driving surface. No one ever drives on the very edge of the road anyways.
   / Time for a new bridge - how to engineer? #38
Yup You need enough pipe to go under the road and the side slopes. With 30 feet of pipe you could have two feet of cover with 3 to 1 side slopes and retain an eighteen foot road way. You can buy it in 20s and 10s so one each would do it. More pipe is cheaper then building headers to save pipe.
   / Time for a new bridge - how to engineer? #39
Dress up the ends of the culvert to make it look like a bridge.
   / Time for a new bridge - how to engineer? #40
That's a really interesting idea. Retaining wall block is pretty cheap and would cut way down on the fill required.
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
CATERPILLAR PC306 QUICK ATTACH HYD PLANER (A60429)
CATERPILLAR PC306...
General Purpose Loader Bucket (A59228)
General Purpose...
2014 International Derrick Digger Truck (A55973)
2014 International...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
