YM 186D replacing seal behind brake drum.
   / YM 186D replacing seal behind brake drum. #1
Yanmar186d
Member
Melbourne Australia
Yanmar 186D
Hi to everyone, I'm replacing my brake shoes on the 186D and found one side had a lot of oil in there, I have removed the drum and found a plate there with 6 or so bolts and removed them, I noticed the plate has 2 threaded holes to put 2 bolts onto so to push the plate out but It's very tight and I'm worried ill brake it,
Am I doing something wrong or is there something else I need to do?
Thanks
Daniel.
   / YM 186D replacing seal behind brake drum. #2
I don't think you can pull that off without taking more apart internal. There is a differential and bevel gear on those shafts. You can probably pop out the oil seal and change without taking the housing out.
   / YM 186D replacing seal behind brake drum. #4
Make sure you have the Dia. Seal or the correct one the best you can tell and pry the old one out. Then just tap the New one back in. A good old screw driver my do the job.
Winston I did what you said, by removing the c clip I got the seal out with a screw driver, once the seal is out the whole shaft pulls out with no force ready to clean and reinstall with new seal.
Thanks to all for the advice.
   / YM 186D replacing seal behind brake drum. #6
Yeah it is a little pitted with rust and have given it a light sand to clean it up and I'll see how it goes when I fit it back on. Thanks
Cheers
Daniel
   / YM 186D replacing seal behind brake drum. #8
good to see it was easy to remove
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2015 Ford F-750 Stellar 10628 10,000lb. 5 Ton Mechanics Crane Truck (A56858)
2015 Ford F-750...
EZ-GO Freedom TXT Electric Golf Cart (A57149)
EZ-GO Freedom TXT...
20FT X 30FT ALL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
