YM 186D replacing seal behind brake drum.
   / YM 186D replacing seal behind brake drum. #1
Yanmar186d
Member
Melbourne Australia
Yanmar 186D
Hi to everyone, I'm replacing my brake shoes on the 186D and found one side had a lot of oil in there, I have removed the drum and found a plate there with 6 or so bolts and removed them, I noticed the plate has 2 threaded holes to put 2 bolts onto so to push the plate out but It's very tight and I'm worried ill brake it,
Am I doing something wrong or is there something else I need to do?
Thanks
Daniel.
   / YM 186D replacing seal behind brake drum. #2
I don't think you can pull that off without taking more apart internal. There is a differential and bevel gear on those shafts. You can probably pop out the oil seal and change without taking the housing out.
   / YM 186D replacing seal behind brake drum. #4
Make sure you have the Dia. Seal or the correct one the best you can tell and pry the old one out. Then just tap the New one back in. A good old screw driver my do the job.
Winston I did what you said, by removing the c clip I got the seal out with a screw driver, once the seal is out the whole shaft pulls out with no force ready to clean and reinstall with new seal.
Thanks to all for the advice.
   / YM 186D replacing seal behind brake drum. #6
Yeah it is a little pitted with rust and have given it a light sand to clean it up and I'll see how it goes when I fit it back on. Thanks
Cheers
Daniel
   / YM 186D replacing seal behind brake drum. #8
good to see it was easy to remove
2003 Mitsubishi Fuso FH (A57148)
2003 Mitsubishi...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
Toro z turn (A56859)
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
