Theory of rear ballast?
   / Theory of rear ballast? #71
That's a good sized pebble!!
edit to add; I use my loader all the time but seldom at max capacity. Having the tire filled makes it easy for routine work.
   / Theory of rear ballast? #72
Stability is obviously something you take seriously with that extended wheel track width on your 5045. Guess you have a lot of work on sloping ground.
In addition to preventing tipping, isn't having enough ballast on the back also about easing the forces and so reducing wear on the front axle ?
   / Theory of rear ballast? #73
Bingo.
Rear counterweight is about more than just having the rear tires stay on the ground. Its about taking weight off the front axle. But if that bucket load of firewood is about the heaviest you ever get (or even a full bucket load of dirt), you simply arent even coming close to your lift capacity. Maybe 1200-1500# is all you are lifting. Therefore your probably not overloading your front axle.
IF I set your total tractor weight to 3500kg, with an even 50/50 weight split (which IMO is probably close counting the tire ballast), it shows you can lift 1000kg (2200#) in the loader and still be 0 in the counterweight column. Probably why you dont have any issues. Since you arent using the loader to its fullest.
   / Theory of rear ballast? #74
I have a hard time finding a flat spot big enough to park on.
Yes certainly when loading heavy stuff a counter weight saves the front axle.
   / Theory of rear ballast? #75
You need to do more loader work :thumbsup:
Dig out some stumps or find some more big boulders, or lift some large logs with some forks. IF you are able to lift everything you try, you arent trying hard enough.
Only time I never find something I cannot lift is when I am sitting on my backhoe.
Your right front tire looks a tad low there LD ...
:laughing:
   / Theory of rear ballast? #76
It was a little low in that pic. Down to ~70psi.
They are supposed to be ~110
   / Theory of rear ballast? #77
I agree. I hit my relief valve very frequently.
   / Theory of rear ballast? #78
I'll throw this wrench into this discussion. Seems like it's about beat the current topic to death.
Rear ballast added behind the rear axle removes weight from the front axle in certain conditions. In other conditions it in fact adds weight to the front axle. Anyone want to try to explain that? :confused2:
   / Theory of rear ballast? #79
If you rears still come off of the ground, then all the weight of the tractor including what rear ballast you put on is now borne by the front axle. Not a good situation.
   / Theory of rear ballast? #80
DING DING DING,,,, James is the winner!!!
Now let the arguments begin...... :D
KUBOTA ZD1211 (A53084)
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
