Corroded battery cable
   / Corroded battery cable #11
My 3016 was only 4 months old when the dealer replaced the cable on mine. They said that there was a batch of bad ones put on at the factory and they have replaced a bunch of them. Well the new one they put on did the same thing within 2 months even being coated with dielectric grease. I spent the 2 bucks and got the old lead replacement end, cut the corroded connector just before the bolt hole and put the one wire under the tightening bolt and the second wire under the other, coated it with dielectric grease and it has been that way for a little over a year now with no further problems. Oh that second wire is a fusible link according to the guy that put the new cable on when it was replaced. Other than that I have had absolutely no problems with my Mahindra. My last tractor was a 2012 Kubota of similar size and I hated that tractor. I love this 3016 and use it a lot!
   / Corroded battery cable #12
I happened to notice my 3016 had a big pile of green fuzz under the red battery terminal insulator after having it for about 4 months.
I took it all apart, cleaned it, greased it and reassembled. I've heard it happens because the lead battery post is not sealed completely to the top of the battery case. I mentioned it to my dealer and he said that he's complained to Mahindra about it, as it's so common, but hasn't seen any improvements made yet.
   / Corroded battery cable #13
I'm wondering how all this turned out, I'm in the same situation. I can't find the terminal end part to purchase it and I don't know what to do about the plastic piece. 11064707_10153229708472728_8925191725679196546_n.jpg1382197_10153229708692728_7449555334681269067_n.jpg10313375_10153229708677728_4636797661225517427_n.jpg
   / Corroded battery cable #15
If you can't get a replacement or whatever, as a workaround: Pour a little fresh Coke across it will kill off the corrosion. Rinse it with a little distilled water, then apply some anti-ox, no-ox, ox-guard, or some other similar antioxidant corrosion prevention that IS ELECTRICALLY CONDUCTIVE. Do NOT use dielectric grease or other non-conductive material. Corrosion typically starts with a dirty or loose connection that isn't making the greatest of contact, sometimes it is just a poor grade of metal in the contacts. Either way, soaking it in Coke to destroy the layers of oxidation throughout the connection, a rinse in distilled water to remove the components of the cola, and a good coat of a conductive antioxidant should have you back in operation for a while.
   / Corroded battery cable #16
When you get a new vehicle with a top post battery.... when everything is clean and shiny new... Tighten up the battery clamps. Then go to your local parts store and buy a can of battery terminal spray. It is a waxy solution that will get into the small cracks around the terminal and the battery case and seal the whole shebang for many many years. I have been doing this since time began, and 99.9999% of my battery terminal problems have vanished.... If this is too much trouble for you, go get a set of side terminal cables and put you in a side terminal battery. My can is so old I had to tape the label back on.... probably from the 60's..
   / Corroded battery cable #17
You can get felt washers soaked with anticorrosion that go on the battery before the cable plus small spray cans for the cables at your favorite auto parts store or megabig retail store. Walmart is our local megabig store. Batterysaver.jpg
   / Corroded battery cable #18
I hair sprayed mine. Mahindra had used a bad batch of batteries from Exide Corp. These batteries leaked at the post insertion and corroded everything it could. They know this and will warranty the battery and the cable for a period of 2 years.
   / Corroded battery cable #19
The top of a lead acid battery is a nasty place. Some batteries vent gas or liquid around the battery post, and almost all batteries vent gas or liquid around somewhere.. People have been fighting this problem for over a hundred years. The horror story and pictures you see posted on this site should make you think of doing something everytime you see an unprotected battery.... for the rest of your life. Here is a picture of one of the batteries in a 2001 Dodge Cummins sprayed with non-hardening wax in the fall of 2001, and the picture of a Mahindra 5035 sprayed in 2011.... can't see any corrosion on either... You don't have to use spray wax... but be proactive with some type of solution...
   / Corroded battery cable #20
Vaseline, (petroleum jelly) is what was the standard preventative measure B4 everything came in spray cans.
Still works today.
Welder (A50121)
Welder (A50121)
2015 JCB 930 6,000lbs 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
90018 (A48082)
90018 (A48082)
