Must have accessories for tractor?
   / Must have accessories for tractor? #11
In regards to carrying firewood or anything else for that matter, maybe you would be well served with a 3pt tote box. Add Quick Hitch to your 3pt and you can set it down/pick it up and never get off the tractor. This keeps your FEL available for piling brush or loading the tote box.
I use my FEL Grapple almost all the time. But I don't think you would get much value out of it on a 2wd tractor. You are going to do most of your lifting/carrying work with your 3pt. Maybe a set of 3pt forks or 2 low prong bale carrier. Then build a tote box that you can pick up with the forks.
You are going to get a priority list going real quick when you start using the tractor!!
Welcome to TBN.
Thanks everyone for the replies. I have a pretty well stocked machine shop so I am not really lacking on non tractor tools.
The carry all / tote box is something I had been thinking of but not know by a name. Seems like you can get a frame for fairly inexpensive and build whatever box on it you want. The quick hitch also seems like a nice upgrade.
What chains are best for a tractor this size for logging and general use? Would grade 70 5/16" chain be plenty or do I need to go to 3/8"?
Do you guys stock extra hydraulic hoses, or the parts to make new ones? The closest store to have parts is about an hour away.
Anything else?
Thanks
Dave
   / Must have accessories for tractor? #13
What about amLand Lever/Grader Scraper to keep the road smooth ?
I also think an HD Roller would be good too.
   / Must have accessories for tractor? #14
I carry two chains on my 95HP 11K lb tractor, a 5/16" for most tasks. A 3/8" for the tough jobs. All my chains are 70 Grade.
On my 47HP 5K lb tractor I only carry 5/16".
I don't stock any repair parts at my farm. But it's only 10 minutes from a supply store.
   / Must have accessories for tractor? #16
In order of importance to me for working with trees:
ROPE
3pt forks
front forks
a mount for your tools (chainsaw, wedges, bowsaw, etc).
   / Must have accessories for tractor? #17
.........tooth bar if you don't have one.
Gene
Second the Piranha Tooth bar, and ballast box- make sure to leave room for carrying your chain, chainsaw, and long handled tools...
Then forget about the tote box and use pallets on front forks for moving wood etc.
We use wood bags on pallets to store and move our split fire wood, other use box pallets or build frames on them.
Regrading bucket forks vs true loader forks, it really depends if you have a QA (quick attach) for your bucket to make switching between forks, bucket, and grapple painless, or not...
We don't have one, but really get great utility using our chain-on bucket forks from the Yankee Warehouse. We never have close to exceeding their rating and the price is prett hard to beat too. I can get them off or on in less than 5 minutes even on a bad day, and they store easily too.
Decide whether you are going to use chain, cable, or straps or some mixture of them as we do. I have also found that some large J-hooks that hook onto one end of your chain can make getting hooked up a lot easier. TruckNTow has them on sale periodically, and they're great for more than just hooking onto axles for pulling. They also make moving our MMM or snow plow around easier, by giving more option for chainong them to the bucket to cantilever them up. I believe we got one set with chains attached from Northern Tool on sale too.
Welcome to TBN!
I have learned a lot about using, abusimg, and repairing.maintaining our tractor, our barn, and even a little about life here.
Thomas
   / Must have accessories for tractor? #18
I have a MF 65 I bought in 1983 and other than normal maintenance has been flawless for me.Just make sure you use the 80w90 in the axle/trans if you use a 3 pt rototiller.
6 Trench attachment (A50322)
6 Trench...
2018 PJ 30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2022 Wacker Neuson SM100 Mini Skid Steer (A51039)
2022 Wacker Neuson...
2022 PETERBILT 579 DAY CAB (A50854)
2022 PETERBILT 579...
ABO TANK (A50854)
ABO TANK (A50854)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
