Identify this scraper blade??
   / Identify this scraper blade?? #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I just bought this 72" scraper blade, and I am curious if anyone can identify it? I will clean it up and repaint it, and might even look for decals, if it is from a company still in business.
   / Identify this scraper blade?? #2
You might want to try searching Kewanee. I have a old larger heavy duty 8' and its the same color and the hole plate is similar. They were made in Kewanee Illinois.
Txdon, I see what you mean about the color- I did a google search for Kewanee implements, and couldn't find a rear blade that was similar, but mine could be really old... I say that based on the fancy pin. Whatever it is, it ain't common.
   / Identify this scraper blade?? #4
Could you get any history from the seller?
Mine has a stamped metal 2" tag on top with the model and serial number.
Seller had no knowledge of what it was, other than he got it used. I will look it over more carefully, but there are no labels, or much painted surface, left. I thought the pin plate was fairly unusual, so maybe that will be what identifies it. I'd be interested in seeing a photo or two of your Kewanee, if you don't mind?
   / Identify this scraper blade?? #6
Don't mind at all.
That's a nice, heavy duty piece. I like all the possible adjustments, too. Color is right, but otherwise, I couldn't say... Thanks!
   / Identify this scraper blade?? #8
Looks close to my 5ft which I was told is a John Deere.
Mike, other than mine is 6', they look identical in about all areas. Funny, but my last blade was a Deere, too, but completely different. No matter, I have some old Kubota orange, so that's what it gonna be. Thanks, everyone.
Hose Reel (A55787)
Hose Reel (A55787)
Little Wonder High Performance Walk-Behind Leaf Vacuum (A55851)
Little Wonder High...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2015 CATERPILLAR 323FL EXCAVATOR (A52707)
2015 CATERPILLAR...
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
