Pat's premium Quick Hitch on a Kubota with Telescopic lower links.
   / Pat's premium Quick Hitch on a Kubota with Telescopic lower links. #21
Agree 100% with this ^^. All implements must be an exact fit or modified to an exact fit for the solid frame type QH.
That is what I ran into when I had a solid frame quick hitch .
Half of my attachments would have needed modified to fit.
Also I brush mow and finish mow uneven ground and with the solid quick hitch my top link could not float through so I also lost the float feature. So my mowers would have need to be modifying for that also.
Quick hitch never got used.
   / Pat's premium Quick Hitch on a Kubota with Telescopic lower links. #22
I am relatively certain that a Delta Hook can be made to fit ANY size implement, without changing anything on the implement. All you do is speed a ton of $$$$$ and put the female receiver on each and every implement. That is what is "one" of the things that is so good about the Delta Hook system.
So your cat 1-2 argument does not apply to this system.
So for conversation purposes if a person has 3 implements that are Cat l & 3 that are Cat ll how much will it cost for the Deta hook so one can attach these implements without the aid of hand tools????????
   / Pat's premium Quick Hitch on a Kubota with Telescopic lower links. #23
I don't know, look at the website and add up the costs. You said it wouldn't work, I said that it would, just that it costs a lot of money.
   / Pat's premium Quick Hitch on a Kubota with Telescopic lower links. #24
you can get the full framed quick hitch at harbor freight reg price $99, I bought mine on sale for $79. Works like a charm!
   / Pat's premium Quick Hitch on a Kubota with Telescopic lower links. #25
Delta hook. First packace.. $1120 gets you the control plate (goes on the tractor) and 2 receivers (goes on each implement). $372 each for each implement thereafter. Do the math for how ever many implements you have.
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
