Need advice welding crack in tiller frame
   / Need advice welding crack in tiller frame #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My 6 ft tiller has a small crack in the frame that I need to fix. I don't weld many repairs like this and want to do a good job. I'm a good advanced beginner. The problem is that there is a crack through the weld in one spot and across a portion of the square stock framework. The first photo shows the frame crack at "A" and the weld crack at "B". I have a Lincoln 170 SP on 220.
The second photo at "C" below shows where the underside was never welded so I figure to clean up and weld that.
On the weld that cracked I figure to grind the weld off and re-weld. Is that the right way? On the frame part that cracked should I just clean it up and weld or should I cut a V in the frame to get better weld penetration? If so, how do I cut that groove? I have a small 3" grinding wheel, a bigger 5 1/2" grinder and I might have a grooved carbide V cutter bit for a drill. I don't weld many repairs but learned correctly at a tech school. Any advice appreciated. Thank you.
   / Need advice welding crack in tiller frame #2
I'm probably an advanced beginner too on welding, but here are my thoughts.
1) The Lincoln 170 SP on 220 will be a little under powered for this job, the specs say 170 amps but it also lists 130 Amps at 20% Duty Cycle so I'm not sure you really get 170 Amp output. It looks like 1/4 inch steel, so according to the miller weld chart for Gas Mig you will need 180-190 Amps. Miller - MIG Welding Calculator
2) I would wire wheel brush the paint off and then used a sandpaper flap disk to clean the area, the pictures make it hard to tell how large the cracks are. I would grind of the weld and v out the crack. I've heard you should drill the end of the crack to relieve stress at that point also.
Good luck with the repair
   / Need advice welding crack in tiller frame #3
I would grind back as muck of the weld as you can to square up the vertical, then weld the crack, grind the excess off the crack, then weld some 1/4" plate over the crack - sort of a band aid, to add strength to the weak cracked area. Do the same on all four sides for strength. Making sure the new plate is welded to the vertical
   / Need advice welding crack in tiller frame #4
Lucky these are some accessible cracks. I'd use a thin kerf angle grinder cutoff blade and open up those cracks for good penetration. And yes go past the end of the crack 1/4 to 1/2" as the metal beyond is fatigued too and has subsurface cracks, you want to grind it out and replace it with weld.
Your welder is fine, if you grind those cracks out your weld will penetrate, thats why you grind it out. Also you will know then if its 1/8 or 3/16.
Kinda looks like it cracked because they fordot a weld. Is it same on the other side? In any case due to the direction of the crack you can tell the direction of the forces and omitting the weld on the underside was not wise.
Can you post an overall pic of the structure of that tiller? I'm trying to get a picture of the forces that are fatigueing those weld joints. I agree that just welding up the cracks "just because" then add some doublers to beef it up.
   / Need advice welding crack in tiller frame #5
Who ever did the welding at the factory, should be shot!:shocked:
I'd drill a hole at the end of the crack before welding.
   / Need advice welding crack in tiller frame #6
I know you will but just make sure to relocate that gas can in the first pic far far away before welding.
Here's a picture of the back of it since I just replaced the tines.
I don't recall a crack on the other side but will double check. Here's a stock photo off the website.
I cracked the implement right side which is the left side the way you are looking. It's made in Italy and gets a lot of abuse from my tilling activities of everything from hardpan clay and dirt to rocks and trash or clay tiles. Maybe I should get a heavier duty model. The damage probably occurred on a patch of really hard clay last summer where it kept bouncing on the surface. Either way, it should fix up fie with a good weld, I hope?
What diameter hole should I drill at the end of the crack?
gas can will not be near things. :laughing:
   / Need advice welding crack in tiller frame #8
What diameter hole should I drill at the end of the crack?[/QUOTE
1/4" or 3/8" at the most, something fairly easy to fill.
I've been really impressed with Lincolns L-56 Mig wire. This fillet weld break test it took 29-blows from a 4-pound hammer to break. :cool:
Thank you.
I think that's the wire I use.
Oh, I have .023 Lincoln wire in now but I also have .030 if I change things over. Do I have to?
   / Need advice welding crack in tiller frame #11
If not, you can buy small rolls at Lowe's. ;)
   / Need advice welding crack in tiller frame #12
The material looks thin, so it probably doesn't matter. Remember to run as hot as you can handle it!
   / Need advice welding crack in tiller frame #13
Looks like its cracking on the non-drive-chain side (passenger side). Is this correct?
I don't see marks from the square u-bolts in your crack pics. Does yours have that square u-bolt an inch in from the crack?
Trying to get a picture of the forces, to recommend how to brace it up. This is difficult not seeing the item in front of me, so more pictures will help (if you're interested).
More pics tomorrow. U bolts for the frame are a couple feet away from this and yes, it is opposite the drive end.
No cracks on the other--drive side --end.
At ShieldArcs thinking, I looked at the other side and found the weld there went around the ends of the square tubing on the bottom. This type of weld is missing on the cracked side so my thinking is the welder missed part of the weld. Plus, the weld that is there looks a little shaky to me like it was too cold.
The crack occurred on the non-drive end so my guess in the forces twist in that direction. So, given that and the abuse I generated along with a poor and insufficient weld and a crack is not unexpected. I really don't want to scab metal onto it because the look would hinder resale. I'm not that good of a welder to make it looked like it "belongs" and I really think clean up and correct weld will solve my problem.
And I know the importance of correct weld penetration. Heat will be all the way up.
   / Need advice welding crack in tiller frame #16
That was mighty observant of Shield Arc! :D
   / Need advice welding crack in tiller frame #17
Maschio is one of the best tillers you can buy but I am totally shocked at the poor welding and lack of welding all around. There is no way that tiller should have ever made it past quality control. When you weld the crack, start your weld a little past the end of the crack and weld back over the crack so you don't leave a crater for a new crack to start.
Big oops on that. It was Sodo that suggested the missed weld. So sorry. :ashamed:
Thank you Sodo for observant post.
   / Need advice welding crack in tiller frame #19
I wouldn't bet the farm that the bottom weld was forgotten! When fabing with square / round tube a lot of people will leave a spot for condensation to weep out. ;)
   / Need advice welding crack in tiller frame #20
A weep hole is one thing and should not need to be more than about 1/4" long un-welded spot, but not welding the whole length is not a thing to do. I suspect it was just forgotten after coffee break or something especially since the other welds were all the way around.
I would double check every weld and if they look wanky, wimpy or what ever your choice of words for poorly welded, re-weld them all. At least with the tiller, you can flip it over to weld the bottom so no overhead welding is required.
All advice for fixing the crack is spot on.
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
