I found a better LockNLube coupler review
   / I found a better LockNLube coupler review #21
Where did you find this?
Ottawa Fastener Supply. Ottawa Fastener Supply They don't have online purchasing but could probably call and order over the phone.
Company that makes them is Univer-Co from Napierville Quebec. Accueil - Univerco but I can't find them anywhere on their site. They seem to be a vegetable grower's equipment place and I'm guessing designed these of of necessity.
Is it this? Grease Coupler, Lock on Grease Gun Coupler, Grease Gun End, Easy Connect/Disconnect Zerk Coupler
   / I found a better LockNLube coupler review #26
Try to do the tilt and twist in a tight spot. :)
On my RZR I can access many zerks straight forward but have no room to do that to remove them.
I haven't run into any yet that were so tight i couldn't tilt and twist. If the spot is tight enough that this method won't work, is there enough room to use the locknlube? I put a lot of thought into purchasing but I haven't found a situation that i NEED it. Yet..
Yes, there are a few zerks in the front suspension where there is enough room for the LockNLube but not the turn and twist.
There probably is not a big NEED, but its sure nice! At least on the RZR. On the tractor, I just find its less messy.
   / I found a better LockNLube coupler review #28
Messy eh, this reminds me of how last time i greased my tractor a few days later i found a big wad of fresh grease on the siding on the back of my garage. Tractor hadn't been anywhere near it. I have no idea how it could have got there. it didn't look like it was smeared on. almost like it was thrown at it or something. weird..
   / I found a better LockNLube coupler review #29
   / I found a better LockNLube coupler review #30
I built this right angle adapter to go with my Lock N Lube coupler. It works well for the two Zerks on the Kioti the LNL does not want to reach under the floor pan.
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
200356 (A51406)
200356 (A51406)
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2014 Dodge Charger Passenger Car (A55853)
2014 Dodge Charger...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
