Box Blade Build
   / Box Blade Build #1
jb1390
Gold Member
Southeastern CT
Mahindra 3550, Hitachi 120-2
I wanted a box blade a little heavier than what I could get at tractor supply, and wasn't happy with the price on the heavy ones.
I used 3/8" mild steel for the box, and a piece of 4" by 1/4" wall box tubing for the crossbar.
It went together very quickly, I had all the parts sheared by my steel supplier.
$335 including tax for a 4x8 sheet cut to size.
It's 20" tall, 24" deep, and 76" wide
   / Box Blade Build
No hardened cutting edges yet, it's just 3/8" steel on the bottom. I have the front and rear cutting edges angled and braced, so it's pretty strong there. Depending on how it's wearing in I may not bother with the bolt on cutting edges, it's not an implement I'm planning on using frequently.
I primarily wanted one for the ripper teeth, and to do rough grading to protect the loader arms.
Seems to work pretty well so far.
   / Box Blade Build #5
Nice built, they can never be too strong! Last winter, my box blade was my best friend, with numerus ice storm, backing up with the rear end of a tough box blade... the ice was just easily chipping away!
   / Box Blade Build #6
As the previous one, nice build !
   / Box Blade Build #7
How about some hard facing?
   / Box Blade Build
Not a bad idea, I don't currently have a stick welder but I've been thinking I need to get one just to learn. Would be nice practice for that process. I do have a miller econotig, theoretically that'll stick weld but I don't have a clamp for it right now, and it's limited to 150 amps at a low duty cycle.
Can you hardface along the edge of a piece of material?
   / Box Blade Build
Double post.....
   / Box Blade Build #10
Sure!:thumbsup:
Contact Mark with Everlast, and see what kind of deal he can make you on a PowerArc 200, or 300.
2020 JLG 1732 4x4 Rough Terrain Telehandler (A49461)
2020 JLG 1732 4x4...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
