50 gallon barrel for 3-point ballast (400 lbs)
   / 50 gallon barrel for 3-point ballast (400 lbs) #31
Don't forget that by transferring weight from the front to the rear you are lessening the effectiveness of the front wheel drive.... as with all things, there are trade-offs. ;)
That will affect steerting, but not overall traction. You'll just end up with more traction in the rear. If you have steering brakes that mitigates the steering issue. Additionally pulling the weight off the front axle is a VERY good thing if you are lifting stuff with a loader. The rear axle is simple & beefy. The front axle is much lighter & has the complex steering stuff. All of which is less sturdy & more costly than the rear axle. So putting more weight on the back to lessen the weight on the front axle is a good thing when dealing with a loader.
   / 50 gallon barrel for 3-point ballast (400 lbs) #32
I AGREE>>>>>
   / 50 gallon barrel for 3-point ballast (400 lbs) #33
I AGREE>>>>>
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
1272 (A50490)
1272 (A50490)
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
Swamp Buggy (A49346)
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
